My Trans Am HID install..
You can do your own custom setup and save some money. Check out the Lighting FAQ and HID Planet.
https://ls1tech.com/forums/appearanc...hting-faq.html
http://www.hidplanet.com/forums/forum.php
hey Tram i was wondering if you still sell the plates for the hella lights? if so i would like to order the high and low set. it probably wont be real soon, got other things i need to do first, but when the funds are available i will let you know and we can work something out if you dont mind. thanks
If you get them too high, they'll start blinding folks.
One guy said he wanted his higher and added some spacers (washers) to the top bolts of the housing to push the top "back" and the bottom up.
He wound up moving the back, said he was getting bright lighted all the time.
Post that link. And I'd like to try the high beam version so they don't have the cutoff. I just don't think mine are up high enough on the drivers side at all.
As of right now I wish I went with hids in the lmc housings.
IIRC the highs are an oval shape, they don't fit in TRAMs adapters correctly. You could make them work however.
Have you spent much time in other vehicles with HID's? The cutoff is "low" to keep from blinding people.
HID's in LMC housings would be less light and not anywhere near as focused.
HELLA 998570001 60mm HB3 Low Beam SAE Headlamp : Amazon.com : Automotive
They can be adapted to work, if you're slightly handy.
