how to align fenders with the door?
Mine looked like:
If anybody has some techniques, I'd like to know as well!
Option 1- look under the fender, there should be two bolts holding the fender to the frame. If both bolts and the tab they go through are intact; take a vice grip and bend the metal back inwards till the fender is flush.
Option 2- if the bolts are sheared off and the tabs are mangled, you will need to drill up through the underside of the fender somewhere where there is metal above it. Then put a couple bolts through into the metal above.
My was like this when I bought it, fixed it with option 1 on one side and 2 on the other.
Hopefully someone can post pics of what I'm talking about.
The last time I made them jack it from the sub frame & the guy looked all pissy because he had too go through the 20secs of trouble unscrewing the rubber mounts off the 4 point lift to screw in shorter ones to fit under the car.
