t/a door panels on a camaro. is it possible
Its a pretty easy swap, there is 1 hook that you have to cut off the TA door panel to get it to fit, its easy to figure out which one it is once you hold the door panel up into position. The lines at the dash line up just fine, The door handle & lock assembly is the same & the only issue with the electric buttons is the mirror adjustment. The windows & locks plug right in. With the mirrors you will have to cut & rewire to get the TA switch to work with the camaro plug. I on the other hand redid the bezel so I could get the camaro button to work on the TA door. Some people just get the mirrors where they want them & then leave it un-plugged.
Raptor..... Don't you already have TA door panels?
Formally Simplɘ Jack
Ya I like the door panels and leather seats on a T/A's way more then Camaro's but I don't like the gray power lock/window switches on them, they look cheap and I might be the only guy that see's that, but that's just me.
