Powder coating valve covers
What needs to be removed from the valve covers? I just removed them from the car and shipped them without removing anything.
I shipped them with the bolts still on and everything. They mentioned something about rubber behind the bolts or something like that? Sounded strange to me. Maybe I should call them back.
Of course, I had the center bolts removed from when I took off the covers (there are rubber grommets under the bolt heads that seal the bolts) and I also removed all the hoses and the filler neck, and lastly, there are (2) plastic baffles on the underside of the PS cover where each of the PCV nipples are welded to the cover - I simply pried them out carefully with a screwdriver and then replced when the covers were done.
You should have taken care of all this removal prior to sending them to the powdercoater - it's really not their job to strip the xtras off your parts but they could have used some common sense as far as the bolts go - take them out of the covers before coating and if you wanted the bolts PC's also - they should just remove the rubber grommets from the bolts 1st.
BTW, cost to polish and quadruple (usual is triple) chrome plate my covers was only $80 each - to buy these chromed outright from vendor costs in the neighborhood of $270
-Jay-
BTW, he can also chrome plastic (shops that can do this are hard to find) I've had a few plastic parts done and he does an excellent job on that too!
-Jay-
I did mine 'Satin Black' and then I powdercoated the coil pack rack 'Almost Chrome'. Looks sleek and clean at the same time...no pocs though, sorry
. . . . I've never had a problem - done at least 4-5 times now. You cannot "slide" your finger around the gasket . . you have "press" it in . . .
