Leaf blower to dry car?
Attachment 312783
I wash mine in the garage. So the floor is wet with no dust or debris to blow around.
Of course if you're using a leaf blower on a dirt or gravel surface, that wouldn't be the best idea.
I have a Black and Decker 230 mph blower that is corded. I've heard not to use a gas blower because it can throw contaminates on your paint.
X2 on the ear protection.
Also no driving around time. You collect, dirt and contamination and that is not what you need to have on the paint when you want to correct or seal.
2 Ways to clean the areas you cannot get with towels.
1- Shut doors/hoods/hatch firmly (Maybe a little on the hard side). Helps the car bleed out excess water.
2- Wash on a incline or use jack stands. A slight incline helps the flow of water.
** Side note, you should need to force water behind the tail light assembly. So if you follow proper washing/rinsing proceedures, you should not have much to worry about.
Top-down when rinsing a car and let the water from the top, push the rest out....
http://www.detailingworld.co.uk/foru...ead.php?t=4637
If the surface does not have a good prepped wax layer then you may need to use more absorbers but again, no need to blast behind the tail lights.
