Ask a Professional Detailer
What I do is use 3 pea-sized drops per application, working at a speed of 5 while using 9-14 pounds of pressure, including the weight of the polisher. I also mist the pad with a shot or two of detail spray to help keep the polish lucid. I demonstrate this technique in all my videos that I do any polishing in.
If you have only watched any of my videos ONE TIME, you probably caught 25% of what I put in them. There ain't a novice on the planet that can retain all of the information that I put in my videos by watching them once. There's just too much information. That's why they are so long. I cover every base, including the ones in the storage lockers at the baseball field.
I know you've been busy and all but..... I'm dying to see that 150+ hour Bentley tag team detail....! Just sayin..
As always, thanks!
Yeah I've never done any paint/body work, worked in a shop, restored cars or anything so I probably shouldn't try it.
Wet sanding obviously would be a last resort as I don't know how thick the clear coat is or have a way to check. I have been using the LC orange pad and 105. What would you suggest?
What product and method should I use to get it out?
