2 5/8 gauges
Old 10-17-2011, 10:09 PM
spilner's Avatar
Default 2 5/8 gauges
So I read the 2 5/8 gauges fit best in the Trans am air vents. I have a 95 that I plan on doing this to. Right now I'm just gonna do electric oil pressure but down the road I want to add volts, water temp or oil temp.
What gauges would you run or what do you have?
I'm looking for red or, silver or white. It's a red car.
I can only find auto meter phantom gauges so far that have the 3 gauges i want in 2 5/8
Thanks guys
Old 10-17-2011, 10:15 PM
AsEpSiS's Avatar
Make sure you buy the electric, full sweep gauges. They're expensive, but are the most accurate. I'm putting h20 temp, oil pressure and fuel pressure in mine.
Old 10-17-2011, 10:17 PM
spilner's Avatar
Ok cool. What brand/model were you looking at?
Old 10-18-2011, 05:00 PM
spilner's Avatar
I've decided on the phantom electric white face with red bulbs
Old 10-18-2011, 11:40 PM
Swiat34's Avatar
Trans Temp and Fuel Pressure would be good choices or maybe a digital multi-gauge.
Old 10-19-2011, 07:49 AM
DopeFedZ's Avatar
If you are having trouble finding all the gauges you want in 2 5/8" you can get the fernco couplers from home depot and use them for "bezels" and run 2 1/16" gauges.
Here is a 2 5/8" gauge in the vent.
Old 10-19-2011, 11:01 AM
GR33N GoblinM6's Avatar
hey whats a "Fernco coupler"? is it in the plumbing section? do you have picture of it by itself? what size is needed?
Old 10-19-2011, 01:52 PM
DopeFedZ's Avatar
You are using the rubber coupling out the clamp below. It's part # 3001-22 they are about $8 each and you can find them at Home Depot.
http://www.fernco.com/plumbing/shiel...flex-couplings
Quick Reply: 2 5/8 gauges
