Project Triple MMM
Thanks for all the compliments guys but the pictures don't tell the whole truth, i've still got a lot of stuff to improve on.
Here's the rear bumper with 3 coats of clear
I went ahead and hung the rear bumper tonight for wetsanding tomorrow
Front bumper
Tonight i also got my wiper cowl painted, grille and headlight brackets. I've been using this color as an accent color for a few different things on the car. It's actually a chrysler color called Brilliant black pearl.
And just on a side note i ordered some of the purple mf cobra towels from autogeek because i was getting low on supplies and i think they suck ***. From alot of the boards and reviews i heard they were some of the best out there and while they feel like a quality thick towel imo they are way too grippy, they don't take polish off very easily and i wiped my chrome caps off with the towels and some quick detailer and they were leaving behind a bunch of fibers from the towel. So anyway i'm gonna call autogeek tomorrow and see if i can return them or at least swap them out for a different towel.
Cobra towel
My old Dragon towel
Basically what i did was start out with 80 grit to really knock down all of the texture then follow up with 180. Then 3 coats of 2k primer sanded with 320, this was followed another 2 times with the final sanding of the primer with 600. Then 3 coats of the base and 3 coats of spi clear.
Gonna flip it over and prime the topside here in a bit. When i lay bc/cc i'm gonna hang the hood so i can shoot both sides at once.
http://www.autobody101.com/content/
http://www.hotrodders.com/forum/body-exterior/
Check out my friend pete, he's got a ton of videos on youtube and he's very entertaining.
http://www.youtube.com/user/swrnc
http://www.youtube.com/user/diyautoschool?blend=1&ob=0
Here's the corner that had been damaged and repaired when i recieved it
After shaping it to get it as close as i could to the right shape
Now is where the real fun begins, after the first block sand i put it back on the car to test fit it, i had some blankets covering my wiper cowl so i wouldn't scratch it and the corner that was damaged got caught up in the blankets and busted off. So i got some fiberglass epoxy and smoothed it back in. Well after getting basecoat sprayed on the crackline was still bleeding through a bit so i sanded the corner back down applied some more body filler spot primed, wet sanded the front down with 600 to denib it and blended the base back in well same thing happened again.
Also the bc and cc layed down absolutely terrible, I know my compressor is a little bit undersized but i don't have $800 right now for a new setup. It has been working out ok for the smaller stuff but i really think with the larger area of the hood and the long strokes it takes for coverage that the compressor just isn't able to keep up and it's not putting out the proper cfm to atomize the paint efficiently. So hopefully before the fbody gathering in may i will be able to get a new compressor and the hood will be getting stripped down and resprayed.
So that left me with trying to make chicken salad out of chicken ****. I'm embarrassed to even show these pics.
After a very tedious color sand and buff
I also ended up with some tiger striping in the base and there's a few spots on the edges that i'm not happy with either, oh well it will be getting redone anyway, good practice i guess as long as the same thing doesn't happen twice.
Back to the curse, to top everything off when i was putting on the hood tonight i put a small nick in the paint on the driver's side rear corner.
Enough of that disaster
Front bumper color sanded and buffed
Tinted tails re cleared
Painted backs of headlights, still have to wetsand and buff the lens their in pretty bad shape, i'm eventually gonna get some new ones i just haven't decided what style i want
Lid and base painted
So i'm gonna get everything back together and head down to winternationals to try and enjoy this piece a little bit since i still haven't even driven it since i got it.
