95 bird analog cluster to newer digital cluster
Old 11-02-2011 | 09:00 PM
k_cash1432's Avatar
Default 95 bird analog cluster to newer digital cluster
Looking to put the newer 97+ cluster in my bird that im swapping a 5.3 into. All i need to do is swap the whole BCM? does anybody have any experience with doin this? Thanks in advance. KC
Old 11-16-2011 | 12:34 AM
k_cash1432's Avatar
Come on im sure somebody has done this swap before...Anybody?
Old 11-16-2011 | 01:17 AM
6898camaross's Avatar
This question was asked awhile back I can't find the thread though you might try a search maybe you'll have better luck than me finding it
Old 11-16-2011 | 01:29 AM
lethal bird's Avatar
If i remember right it can be done but its not an easy task. But i may be wrong.
Old 11-16-2011 | 11:44 PM
k_cash1432's Avatar
I tried finding it, I remember reading on here of a guy who said he did it but thats all he said he said he swapped the whole BCM and harness from the headlights to tails...
Old 11-17-2011 | 01:24 PM
XxXTransAmXxX's Avatar
It has to come from a 97 car. As they are still plug-n-play. The mileage will need to be re-flashed in the cluster as it is stored internally
Old 11-17-2011 | 01:33 PM
It won't be plug and play. I wish i could find that old thread but the guy that did it said after it was said and done it wasn't worth it.
Old 11-17-2011 | 02:32 PM
OK...well that's your thoughts....
I have put a 97 cluster in a 93-97 Early 4th Gen (car was a 93). Granted the motor isn't together or running, but all the base electrical works and lights up as well as odometer. Yes there are differences in the 98-02. The architecture of the 93/97 years were the same. For proof IT WILL WORK I have attatched pictures of the two model year's IPC connector for pinout purposes showing the function of each cavity is identical.(93 on top, & 97 on bottom) IT WILL WORK (I was involed in the thread as I was doing the research for it.)
Old 11-17-2011 | 03:05 PM
I never said it couldn't work i just said its not plug and play.
Old 11-17-2011 | 03:06 PM
It is plug in play! How isn't it the cluster is the same connector?! The odo needs reflashed to show correct mileage is all
Old 11-17-2011 | 03:23 PM
A16 and A8. Those 2 pins will need to be moved around i believe.
Old 11-20-2011 | 09:45 PM
k_cash1432's Avatar
so if i get the 97 interior harness i can do this mod with minimul effort? FYI my car is a 95 V6 that im dumping a 5.3 and 6 speed. My engine harness is a 98M6 harness im converting to use a 411 PCM.
Quick Reply: 95 bird analog cluster to newer digital cluster
