My LS1 Trans Am Projector & HID Conversion Thread
Old Dec 20, 2011 | 02:47 PM
  #61
HibachiZ28's Avatar
FWIW: I was sent a set of 4 low beam 60mm adapter brackets. I only need the 2 as the high beams are a different shape and mount. If anyone wants them, they're for sale. Shoot me a PM or check the classifieds. Thanks.
Old Dec 21, 2011 | 01:03 PM
  #62
HibachiZ28's Avatar
Purchased some mounting hardware and mounted the brackets. I'm going to run them as-is. If I don't like the look I'm going to paint 'em:
Old Dec 21, 2011 | 01:19 PM
  #63
No Juice's Avatar
Where did you buy the brackets from?
Old Dec 21, 2011 | 01:20 PM
  #64
HibachiZ28's Avatar
I've got two for sale:
https://ls1tech.com/forums/parts-cla...onversion.html
Old Dec 21, 2011 | 01:25 PM
  #65
No Juice's Avatar
Do you still need to use the stock headlight bucket with these brackets?
Old Dec 21, 2011 | 01:29 PM
  #66
HibachiZ28's Avatar
Nope. You need to re-use your factory bolts that hold the bucket in place, though, along with the spring. The 2 notched cutouts on each bracket (One on top, one on the outside) go right where the factory bracket bolts are. The round hole drilled on the bottom inside area is for the spring.
Old Dec 21, 2011 | 01:31 PM
  #67
No Juice's Avatar
Wonder if these would work with the TSX's
Old Dec 21, 2011 | 01:37 PM
  #68
HibachiZ28's Avatar
Hmm. That was my plan as well, either TSX, TL, or Lexus RX, etc. The step on these Hella's bothers me. If I had a spare TSX laying around I'd check it for you.
Bracket dims (measured with a tape measurer - not including notched portion):
Height: 4"
Width: 6"
Oval dims:
Height: 3.25"
Width: 3.75"
Old Dec 23, 2011 | 04:50 PM
  #69
HibachiZ28's Avatar
I reinstalled the lows, this time with brackets. Still need to aim them. Also debating if I want to paint them or not. I'm also going to change the setup a bit and add some washers to better hold them in place. That should make things a bit easier to adjust and keep in place:
I'm waiting on the high beam brackets. Either going to fab them up with a buddy of mine and his aluminum skills, or use the other set I have for the low beams and make them work for the highs. Playing that by ear at the moment...
Old Dec 24, 2011 | 06:51 AM
  #70
The Alchemist's Avatar
UNDER PRESSURE MOD
Originally Posted by HibachiZ28
Okay, the uptick of the cutoff is really bugging me out. I'm going to take these apart this weekend and adjust the cutoff. I want it flatter like my MH1's. Comparison...
Morimoto MH1 in my Jeep:
Hella 60mm in my Trans Am:
Once I modify the cutoff shield I'll take new cutoff photos as well as ground shots.
The uptick only gets worse the further back you are from an object. It's really fristrating when you're following someone 5-6 car lengths behind them and you get a horrible light dispersion. I had to drive my car 3 times this week, and hated the thought of turning on my lights. I have the Hella 60mm projectors and I'm ready to change them for a different projector.
Old Dec 24, 2011 | 08:13 AM
  #71
MUSTANGBRKR02's Avatar
What projector would you use Alchemist?
Old Dec 24, 2011 | 09:46 AM
  #72
UNDER PRESSURE MOD
That's the thing, I don't know. I just know that I hate my current lights.
Edit: it's not that I hate the lights, because they are leaps and bounds better than the sealed factory beams, but since they are so much brighter, you can see the sharp cutoff and how profound the uptick is. Part of the issue is my daily driver is a Saab 9-3 with factory HIDs that have almost no uptick to the projector. So I'm used to them, and then the T/A has this massive uptick which to me is very distracting.
Old Dec 24, 2011 | 11:18 AM
  #73
I have never even thought about lights until I was driving side by side with a buddy in his Camaro a few weeks ago and his lights were so bright compared to mine I paced him the rest of the way back to town.
Old Dec 24, 2011 | 11:14 PM
  #74
gm02ceta's Avatar
Looking nice HibachiZ28!
I notice in one of your pic of the low beams mounted that you have the screws with the springs fully compressed. Have you encountered clearance issues with the rear of the bulb making contact with the back of the light brackets preventing them from closing or opening?
Old Dec 26, 2011 | 04:15 PM
  #75
HibachiZ28's Avatar
Thanks guys. I am ordering another set of projectors. I'm going to bake them and take apart the light. Once I accomplish this I will then attempt to adjust the cutoff shield. If this fails, I'll just sell them with the stock shield. I'm looking into TSX, TL and other projectors that I can seal and work with. I may even try to seal an MH1 and get that working, but we'll see how things go....
CETA: No clearance issues. The reason I have them all the way in is due to the aim. I guess the bottom corner spring is super tight as it requires this much adjustment to place the cutoff at a decent height.
Old Dec 9, 2012 | 01:03 PM
  #76
White.Lightning's Avatar
From the dead. Did you ever mock up a different projector housing?
Old Dec 17, 2012 | 05:35 PM
  #77
HibachiZ28's Avatar
Negative. They actually work very well and I am happy with them. I'm sure I can tweak the whole setup a bit, use a different projector, but for what the OE lights are in comparison, this kit just rocks. I still need to paint the aluminum brackets black, but I need to get the car running first
Old Jan 21, 2013 | 09:59 AM
  #78
HibachiZ28's Avatar
Here is are two quick videos so you can see (I'll add more later)...
Hi & Low Beam:
Low Beam only:
And some photos:
The uptick of the cutoff is really bugging me out. I'm going to take these apart shortly and adjust the cutoff. I want it flatter like my MH1's. Comparison...
Hella 60mm in my Trans Am (Before I leveled it out):
I'm going to paint the brackets bracket I think. I'm not real worried with how they look, but more how they perform.
Old Jul 19, 2016 | 12:15 PM
  #79
SarGntoperez's Avatar
Default Brackets
Do you know rhe thickness of the bracket and maybe the dimension of the holes?
Old Jul 19, 2016 | 05:16 PM
  #80
Default Bracket dimensions
Height: 4"
Width: 6"
Oval dims:
Height: 3.25"
Width: 3.75"
By any chance do you know the thickness of the plate and also the size oh the holes were the light mounts to the bracket?
