Squeaky Door
Old Mar 12, 2004 | 06:01 PM
ChitownLS1's Avatar
Default Squeaky Door
My drivers door has started to squeak when opened and closed. What lube should be used to get rid of this?
Old Mar 12, 2004 | 06:02 PM
XtinctHawk02's Avatar
WD40, does wonders.
Old Mar 12, 2004 | 06:21 PM
LawmanSS's Avatar
I always use white lithium on door hinges...
Old Mar 12, 2004 | 07:23 PM
VIP1's Avatar
Copy & Paste Moderator
The dealer uses white lithium grease in spray form. You can get it at an auto parts store for just a few dollars (its usually in a white or green spray can). You can use that or something thicker and hand apply it. I like the ease of the spray stuff, hence that is what I use.
--VIP1
Old Mar 12, 2004 | 07:42 PM
Jpr5690's Avatar
slicone is reccomended in the manual... but hell anything will work
Old Mar 12, 2004 | 07:43 PM
Jpr5690's Avatar
wd40 = easy but tends to wear down quick
Old Mar 12, 2004 | 10:40 PM
True Dat!
Old Mar 12, 2004 | 10:55 PM
XuhQshinR's Avatar
Originally Posted by XtinctHawk02
True Dat!
I agree. WD40 actually stands for Water Displacement perfected on the 40th try. It is not a long lasting lube but works great in a pinch. Great for frozen Locks!
The company that owns WD40 Brand also owns 3-IN-ONE and has a brand of White Lithium Grease in a can as someone mentioned in an earlier post.
3-IN-ONE Professional White Lithium Grease has a variety of uses and is better suited than WD40 for use on the following :
Automotive: Hinges, locks, latches, seat tracks, strike plates, cables, distributor cams, battery terminals, radio antennas, windshield wiper mechanisms, bolts, bearings and more.
Old Mar 12, 2004 | 11:17 PM
LS1Baron's Avatar
Remone the door panel and protective plastic. Support the door well, and remove the hinges. Machine wash warm, tumble dry low...
Just kidding. Lithium grease works fine.
Old Mar 14, 2004 | 07:00 AM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
I have a small 1/2 oz. container of CRP Molybdenum grease from a radio control car I owned about ten years ago. The stuff works great on my hinges.
Old Mar 14, 2004 | 09:44 AM
99huggerorangeZ's Avatar
i have a bottle of the 3-IN-ONE stuff and it works great
Old Mar 15, 2004 | 10:17 AM
VoodooWS6's Avatar
go to the dealer, and get the GM spray grease for doors..It works awesome! Also lasts and is clear.
Old Mar 15, 2004 | 10:26 AM
ChitownLS1's Avatar
Will do.
Thanks.
Old Mar 15, 2004 | 11:36 AM
do you know what the part# is by chance for the spray grease?
