Old May 13, 2016, 02:58 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Specifications & General Maintenance
Print Wikipost
Engine bay cleaning?? HELP!
Old Nov 24, 2011 | 01:43 PM
blueBerryLS1's Avatar
Default Engine bay cleaning?? HELP!
Whats a good way to go about cleaning the engine and engine bay without shorting or screwing stuff up?
Old Nov 24, 2011 | 10:45 PM
transam5.7lt1's Avatar
I'll say pressure wash it with the engine running, I was very afraid to do it also, finally did it and it didn't mess up anything, just take your time.
Old Nov 25, 2011 | 12:23 AM
stephen4036's Avatar
ive NEVER had a problem washing engine bays till my z28.. i had electrical problems for 2 weeks afterwards.
Old Nov 25, 2011 | 01:06 AM
Z28Mayhem's Avatar
The best way I have done it, and I have been detailing cars for 8 years, is if you're worried about shorting anything out cover what you need to with plastic bags or hand wash it. Takes a little longer but you don't have to worry about water just being sprayed all over everything. Honestly though i've sprayed down so many engine bays and have never ran into any issue.
Old Nov 25, 2011 | 01:28 AM
cjf's Avatar
cjf
I'm a detailer at a GM dealership, and I spray the entire engine bay with degreaser leave for 2 or 3 Min's then blast clean with the high pressure washer, next I use the air hose and blow dry the entire bay dry. Let it sit for as long as possible for a final air dry and you should have no problems.
Old Nov 25, 2011 | 01:30 AM
54inches's Avatar
Did that EXACT same thing yesterday and worked well.
Old Nov 25, 2011 | 06:00 AM
BOBS99SS's Avatar
Captain Double Post
^i do the same thing, but i will add becareful with any kind of degreaser, some of that stuff is pretty harsh, i spray mine off every few months,it doesnt get that dirty,then i hit all the rubber and plastic with stoners trim spray,works out pretty good.just use some sence when you are pressure washing ,try to use less water, air hose is a must imo, and i also let mine run
Old Nov 25, 2011 | 09:15 AM
djfury05's Avatar
Here is what I do.. I let the engine warm up to almost operating temp and then turn it off. Then I spray some Simple Green all over the engine bay. I let that sit for about 2-3 minutes. Then I will rinse it off with hose water just an open end no handle on it. Then I will get my Engine Brite foamy **** out and spray that all over the engine bay and into nooks and crannys. Let that sit for about 4-5 minutes and rinse. I rinse mine VERY well, literally like 8-10 minutes of standing there with a hose getting everything out. After that I grab my shop vac and suck up any water I can see and finish with waffle weave drying towels. Never had a problem. I have a thread about my engine bay build up that you can make an opinion on if you want to follow my steps.
Old Nov 25, 2011 | 09:41 AM
Adam1982's Avatar
Basically what every one else has said. Warm the engine up a bit, shut off. Spray it all down with DP engine degreaser, let sit. Agitate with brush, rinse off with hose. Blow dry with compressed air. If you are really worried you can cover fuse boxes etc with plastic bags or tin foil, but you shouldnt have any issues.
Old Nov 25, 2011 | 09:47 AM
camaroboy14's Avatar
Has anyone tryed using scrubbing bubbles?? I read on a BMW forum they use that, what u think ?
Old Nov 25, 2011 | 11:43 AM
bill12690's Avatar
I don't know if it's just my car or what, I've covered everything necessary to cover but it seems like my car just acts up every time the engine bay gets wet anyway. The last 3 times I did this, I rinsed, and blew out the engine bay with a leaf blower and air compressor.. then, the alt was overcharging, throwing lights all accross the dash, blew both high beams once. I've since then gotten a new alt, but haven't cleaned the engine bay since, so i'm not sure if that was the problem or not.
Old Nov 25, 2011 | 12:46 PM
^ that's crazy :/ I wonder why?? I was thinking about cleaning my engine bay tomorrow but don't want any problems :/ so guys what exactly do you cover when cleaning the engine bay
Old Nov 25, 2011 | 03:55 PM
bill12690's Avatar
i've really never figured out why.. I'm not sure if it was an issue with the old alternator or what, so I got a new one but I have yet to clean it again. After a few days or airing out it was fine, but things were definitely screwy until then. I didn't even drive it because I didn't want the alt to continue to overcharge. I mean the voltage gauge was pegged basically.
Had the old alt tested and they said it was fine though..
Old Nov 25, 2011 | 03:59 PM
nascarnate326's Avatar
Do you have an optispark?
(yes) please push back on your browser now
(no) degreaser and pressure washer at 3 ft distance between engine bay and tip of pressure washer
Old Nov 25, 2011 | 06:53 PM
bayer-z28's Avatar
Just don't spray under the intake. it can puddle in the knock sensor holes and cause headaches.
Other than that, spray away. I like the idea of letting the degreaser sit for a while.
Old Nov 26, 2011 | 08:41 AM
mrrman's Avatar
good read....this is my next step
Old Nov 26, 2011 | 01:39 PM
54inches's Avatar
For those that have not done it, you might the starting the engine AFTER you spray it down with cleaner and BEFORE you spray it off with the water.
Old Nov 26, 2011 | 03:12 PM
GoFast908Z's Avatar
Oh there is so much win here.
Old Nov 26, 2011 | 06:07 PM
thecobrahunter's Avatar
X2 by hand. Takes a little longer, but looks immaculate.
Old Nov 26, 2011 | 06:31 PM
54inches's Avatar
Did you make those VCs and the black "other" covers?
