Blue TA odometer and white LED warning lights FTW!
Old 12-27-2011 | 02:38 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I intend to try my desoldering iron first - it basically has a small rubber bulb you compress, so when the hollow tip heats the solder to the point that it melts, you release the bulb and it sucks the solder right up. If that doesn't work, I'll probably just use solder wick...thankfully, Radio Shack is a 5 minute drive away for me.
Old 12-27-2011 | 04:00 PM
HotWhipT/A's Avatar
This device is the same idea. You push it down to load and then press the yellow button while the solder is melted. It sucks it right up. I didn't have much luck with the wick in this case.
Old 12-27-2011 | 06:41 PM
XxXTransAmXxX's Avatar
I LOVE my desoldering pump! I agree, and really after I got the pump I NEVER use the wick anymore, it's just so much more precise & neater...
Old 12-27-2011 | 07:38 PM
DaRReLL's Avatar
99-02 Camaros and Pontiacs have the 3 red SMD LEDs. Their is NO film on the odometers!
That is some good info right there. I got an 02 Camaro. **** I guess I have to put in some blue LEDs. No resistors needed for these LED's? Why would you need one for the ASR & FOG lights then?
I just hate frickin' LED's
Old 12-27-2011 | 08:03 PM
HotWhipT/A's Avatar
No resistor needed if your going to replace a stock LED. It'll already be made for it.
Are we talking about the ASR/TCS and fog light switches? I haven't bothered to look at those. I imagine they are LEDs too. Not sure if you can replace them though.
For the most part now, most of your standard interior lights like the 194, 74...etc. you can buy an LED replacement that will fit right in and it already has the resistor built in.
Old 12-27-2011 | 09:10 PM
MeentSS02's Avatar
Those switches use standard bulbs, hence why they require resistors to make LEDs work. They are a rather large pain to do because you have to be able to squeeze everything in to such a tight area, but it is certainly doable. White LEDs to illuminate the lettering really makes them look nice (and modern), and I changed the on indicator lights to red just for something different.
Old 12-27-2011 | 10:48 PM
Reckless95z's Avatar
Would this be easier on a 95 Camaro would i just have the film and swap out the bulb with a colored led?
Old 12-27-2011 | 10:55 PM
HotWhipT/A's Avatar
I don't know anything about the 93-97 clusters. All this refers to 98 + clusters.
Old 12-28-2011 | 02:17 AM
GENE510SS's Avatar
did mine almost a year ago and love it! in this pic its 80% done. hvac is all blue now too.
Old 12-28-2011 | 12:27 PM
2000_SS's Avatar
i did all mine like that too, just need to do the steering wheel controls and its finished.
Old 12-30-2011 | 12:20 AM
Irish350's Avatar
dug up a picture of my first attempt... gives some idea of color at least? the warning light is overpowering but theyre white leds
im not sure if i got the 'dark' rubber piece on the wrong side (if it needed to be grounded/conducting and couldnt it may account for the image) or if it was an issue with my soldering (which i kinda doubt, but it could happen).
Old 05-22-2012 | 03:31 PM
  #32
DoggyB22's Avatar
Good write up man!
Old 05-22-2012 | 07:13 PM
  #33
Trans.Am98's Avatar
Good info
