How do I remove my door panels?
Theres three large screws (two under the arm rest, one at the front of it) and one skinnier one through the handle bezel. Plus one at the upper inside corner to remove the mirror wire bezel kinda makes it easier. Maybe one more near the mirror switch I'm not sure on the Pontiac (there is on a Chevy). Be careful and use something really thin and flat to remove the window switch or you'll break it (it is 10 year old plastic).
Once you take all the screws out, pull your door locks to the unlocked position and pull off the door lock slider (black plastic piece with the orange on it) pop out the power mirror/power window switch panels, disconnect the wiring harness on the back. Once everything is disconnected, lift UP like Cape said. This will pull the panel up, and the clips out of their holes. Pay attention to how it comes up and out, that way you can get it back down and all the clips seated easily.
I remember sitting there trying to get 2 clips to go back into place after I brought the panel down. All you need to do is lift up and re-seat them lol.
This should help too! Click next at the bottom of each page.
http://shbox.com/page/windowmotor3.html
