Swirl marks
Old Apr 10, 2012 | 12:52 PM
blawson's Avatar
Default Swirl marks
Anyone have any tips on how to get swirl marks out of paint? Sort of new to the detailing stuff so I'm open to any opinions
Old Apr 10, 2012 | 01:15 PM
BrianSF-GA's Avatar
This is what I use with an orbital buffer, not a polisher/grinder! It may take longer, but the results are better and there is no chance of "burning" your paint!
Old Apr 10, 2012 | 08:14 PM
CamaroSS27's Avatar
start by reading some of this thread your head will hurt with information, basically best way is to get a porter cable and some meguiars 105 and 205 and basic detail stuff.
https://ls1tech.com/forums/appearanc...-detailer.html
Old Apr 10, 2012 | 08:39 PM
egott_91's Avatar
To get rid of them, you will need a polisher and polishes. Also, once you have the swirl marks removed, you will want to have quality products to keep it from scratching. Therefore, you will want quality towels and wash mitts along with a proper wash technique
Old Apr 10, 2012 | 09:45 PM
The Mighty Texan's Avatar
I was going to suggest this also
Old Apr 10, 2012 | 09:58 PM
SparkyJJO's Avatar
Read about 19 pages, then my head exploded.
Now I wonder if I deserve an fbody since I don't understand half that stuff, nor do I have a garage to store it in all the time, or good constant access to a place to properly wash it.
I feel like a neglectful owner now
Old Apr 10, 2012 | 10:13 PM
CamaroSS27's Avatar
We all start somewhere, just start with a little and build up, its really easy just a lot of products and methods but you will learn quick.
Old Apr 11, 2012 | 06:19 AM
BOBS99SS's Avatar
Captain Double Post
Look on autogeek.com they have a killer kit that will come with a pc/pads/compounds, for the price you cant beat m105,205 its proven and works well, there is a ask a pro detailer thread, why. Dont you take some pics of the car and post them ,then gofast98 will give you the best info step by step, there are also alot of good vids on youtube to help you start using a pc,porter cable
Old Apr 11, 2012 | 08:13 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Not recommended but in general there are people out there who can polish swirls out by had with the appropriate technique, passion, arm strength, and consistancy. The total cut is no where near a DA or rotary but does work. Just need time and dedicated space.
Old Apr 11, 2012 | 10:38 AM
Jr.Samples's Avatar
I wet sand with 1500 use Meguires fine cut then on to Meguires 2.0 swirl remover. I finish with a polish or carnuba wax. Looks great.
Old Apr 11, 2012 | 12:15 PM
BrianSF-GA's Avatar
This is exactly my "system" only without the wet sand step.
Old Apr 11, 2012 | 12:33 PM
ynkssws6's Avatar
As suggested...check out the ask a pro thread and do yourself a favor and join autogeek. Detailing will become addicting.
Old Apr 11, 2012 | 10:51 PM
blawson's Avatar
thanks for the replies. that thread had alot of good stuff in it.
im going to get the 105 this weekend. from what i read, i use the 105 then the 205 then wax. is that correct? and do i need a buffer? if i can do it by hand id rather do that, im not worried about how long it takes
Old Apr 11, 2012 | 11:02 PM
607motorsports's Avatar
I just did this exact process on my black 02 SS. The paint on the car is amazing but there were some surface scratches and swirls. I used Chemical Guys V36 polishing compound with a Lake Country orange pad and then Chemical Guys V38 final polish with a white Lake Country pad. The results are nearly flawless
Old Apr 11, 2012 | 11:17 PM
Latch's Avatar
Don't worry, you're not the only one. I've never even put a coat a wax on my car, let alone tried to fix the swirls. It's hard to really get into the detailing thing when your car is a DD that sits out in the elements all day. I'd love to make it a show car but it's just not practical for everyone.
Old Apr 11, 2012 | 11:42 PM
websdown's Avatar
I just finished up my Black 98Z with Clay Bar then Porter Cable 7424 Lake Country Orange pad &Meguairs Ultimate Compond then Lake Country White Pad&Ultimate Polish and NXT 2.0 wax. Turned out GREAT for my first time. I was alittle hesitant at first also. It took a total of about 6 1/2 hrs to compond but thats where it counts the most. Then only about 4 hrs for polish. And the wax took no time at all the finish is so smooth wax goes on and off like butter. Good Luck.
Old Apr 12, 2012 | 08:23 AM
CamaroSS27's Avatar
Try meguiars m105 and m205 then blackfire you will be even more blown away with results.
Old Apr 12, 2012 | 08:24 AM
CamaroSS27's Avatar
Yes you will need a buffer they really are not that expensive plus they last forever basically
Old Apr 12, 2012 | 08:45 AM
ynkssws6's Avatar
Yeah pick yourself up an orbital. It's well worth the initial investment.
Old Apr 12, 2012 | 09:13 AM
Off topic a bit but how is the Blackfire wax? I've been contemplating ordering some...
