Write Up: C6 Steering Wheel in an F-body
Old 12-06-2018, 06:08 AM
  #441
Fieroluke's Avatar
Yes, Google "Cancelling Cam" and switch to images. It'll be obvious which part the tower ist...
Old 12-06-2018, 06:09 AM
  #442
Fieroluke's Avatar
It should be 12V...
Old 12-11-2018, 08:14 PM
  #443
HotWhipT/A's Avatar
Let me tell you, I've been putting off installing this for probably 2 years and for good reason. I had a feeling it was going to be difficult and that proved to be very true. I consider myself very mechanically inclined as I've done 99% of all the work myself on my car, and this stupid thing ranks up there with the hardest thing I've ever done. It took a solid 4 hours, mostly trying to piece the thing back together, especially the geared ignition switch part not wanting to work right.
Steering wheel is a brand new C6 wheel with blue stitching and I was able to find a OEM cover at the junk yard to delete the buttons. I got a airbag off of something like a G6 and found this nice blue emblem overlay to get rid of the red.
Old 12-11-2018, 09:00 PM
  #444
Cole Train's Avatar
^^^ I'm so glad i didn't change the column shaft and went with a Grant adapter and modified it to work with the wheel
Old 12-12-2018, 09:15 AM
  #445
Platinum WS6's Avatar
How much work was it to alter the Grant adapter?
Old 12-12-2018, 10:50 AM
  #446
LT4vert's Avatar
That came out looking great Hotwhip, really tasteful.
Old 12-12-2018, 02:38 PM
  #447
HotWhipT/A's Avatar
Thanks
Old 12-12-2018, 07:40 PM
  #448
Cole Train's Avatar
it just took modding it to make sure i could get the airbag wire through
Old 12-14-2018, 08:38 PM
  #449
Phoenix'97's Avatar
I actually think the 01-03 Grand Prix wheel looks nice, and most important you have the same steering wheel controls as your stock steering wheel from the look of it!
Old 12-23-2018, 02:35 PM
  #450
chumbini's Avatar
Default Radio wires
these are the colors that correspond to linking the 2012 C6 wheel to the 2000 Camaro wheel in terms of radio controls.
the Camaro has different colors once you remove the airbag cover. You have to follow the column down to where the yellow airbag wires connect. There is an adjacent thick gray wire that will follow the yellow Airbag wire up and through the clockspring. It will have 4 wires inside of it. These are the wires we will use for the radio controls.
under the dash, the colors that enter the gray wire are
yellow- 12volts
dark blue- radio control output
gray/black-switch illumination
black- ground
the colors change once they reach the wheel. Pull back the gray wire connector UNDER the dash and write down the new colors that will follow up to the connector in the wheel. I don't rememnber all the colors but I do know that blue becomes green, red becomes black, yellow stays yellow and grey becomes pinkish. Do yourself a favor and look for yourself.
anyway. If you are looking where the original colors plug into the new colors, pay attention below.
C6 wheel wires
black-ground
yellow-switch illumination
purple/white- 12volts
blue- steering wheel radio control output.
so if we use the original colors under the dash, here is how the wires connect
C6. Camaro
blk- black(which is actually red on the connector)
yellow-gray/black
purple/white- yellow
blue-blue(which is green on the connector)
the blue wire will connect to PAC-1 converter that allows steering wheel controls to interface with my Kenwood radio.
anyway, it worked
Old 01-10-2019, 10:36 AM
  #451
Fieroluke's Avatar
Smile Circuit boards arrived
Finally, I got around to have circuit boards made! These are the boards to make the Cruise & Radio controls (as well as the Trip computer buttons) available using the C6 wheel on the F-bodies.
At last some progress...
The following users liked this post:
SnIpEz (09-03-2020)
Old 01-17-2019, 06:33 PM
  #452
Cole Train's Avatar
can't wait
Old 01-21-2019, 10:37 AM
  #453
Diesel235's Avatar
There a sign up list for one of these? Definitely on my "I want it" list
Old 01-22-2019, 02:56 AM
  #454
Fieroluke's Avatar
No, but I have 10 circuit boards, so I can build up to 10 units, and I'll start by building 2-3. I'll post here when I have some available.
Old 01-27-2019, 10:44 PM
  #455
LetsRide's Avatar
I’m in for one. Any idea of a rough estimate for the cruise adapter?
Old 01-31-2019, 07:23 PM
  #456
Cole Train's Avatar
Fieroluke still think you'll be in the states in February and will be able to ship the one to me then?
Old 03-16-2019, 09:05 PM
  #457
Cole Train's Avatar
any update on the boards? i haven't heard from you in a while. i know you mentioned you may ship me one when you were state side but never heard anything
Old 05-21-2019, 07:24 PM
  #458
LetsRide's Avatar
Here for updates as well.
Old 05-23-2019, 07:35 PM
  #459
trodo302's Avatar
Also very interested
Old 05-24-2019, 03:20 AM
  #460
Fieroluke's Avatar
Cole Train's PCB is in the mail. I do have a few boards left so I could build a few more, PM me if interested.
Quick Reply: Write Up: C6 Steering Wheel in an F-body
