Window Tint Removal
Old Feb 18, 2013 | 02:15 PM
k_cash1432's Avatar
Default Window Tint Removal
Pickep up a 2000 TA that somebody "had" the windows tinted, but they ripped it off before I purchased it, now it has that hazy film still on the windows. I have seen window tint remover but didnt know if it was worth it or if their is some home brew/remedies that work better? Thanks!
Kenny
Old Feb 18, 2013 | 03:09 PM
jbridwelltransam's Avatar
Heat gun, soapy water and a razor blade. Check out these crazy Australian's advice!
Old Feb 18, 2013 | 04:53 PM
Blackpanther99's Avatar
Yup^ Whenever i got my trucks tint removed to install a new one the guy used soap with water and a little razor blade.
Old Feb 18, 2013 | 06:03 PM
95badboy's Avatar
Just be sure u blade with the soapy water and be carefull not to scratch up your windows
Old Feb 18, 2013 | 08:24 PM
k_cash1432's Avatar
Hum, guess ill give the Heat gun, soapy water and a razor blade a try. Wont be till next weekend though have to go to work tonight till thursday.
Old Feb 18, 2013 | 08:39 PM
Zlow28's Avatar
Windex works good aswell. The older the tint is the more difficult it is to get out though. Make sure your razor blade is sharp
Old Feb 18, 2013 | 09:54 PM
Think of it as wet sanding your window with a razor blade. Plenty of lube and a crisp blade.
Old Feb 18, 2013 | 10:12 PM
Daniel Richards's Avatar
you don't need the heat gun soapy water and a good stainless steel razor blade will do fine.
Old Feb 20, 2013 | 09:51 PM
porksoda's Avatar
I personally have never tried but I hears aircraft stripper takes it clean off. Seriously
Old Feb 21, 2013 | 11:33 PM
k_cash1432's Avatar
I do have a gallon of that in the gurage I might just give that a try! We got a foot of snow dumped on us this week and I have been on call so not much going on for me. MR Buddy heaters only kick out so much heat
Old Feb 22, 2013 | 07:50 AM
nascarnate326's Avatar
do not use a razor blade on the hatch if you want your defroster to work. even if you think you can do it...dont. It only takes one tiny cut to mess up the whole thing.
Old Feb 22, 2013 | 07:52 AM
VAformula's Avatar
Paint thinner works better than soap and water.
Old Feb 22, 2013 | 09:28 AM
JerseyLS1TA's Avatar
Heatgun, soapy water and a sharp blade worked for me. The back hatch sucks doing
Old Feb 22, 2013 | 11:06 AM
MeMz's Avatar
Isopropyl alcohol and paper towels with some elbow grease is the safest route. Heating it up helped a lot too.
Old Feb 22, 2013 | 11:31 AM
blackpala96's Avatar
Ammonia will strip the "glue" off like you wouldnt believe. Just make sure you are in a ventilated area.
Old Feb 23, 2013 | 09:54 PM
GoFast908Z's Avatar
This is SPOT ON. Listen up.
No heat needed
Soapy water (Johnson & Johnson's baby shampoo, the "no tears" kind is perfect)
And STAINLESS razor blade.
For the back window just switch to a plastic razor blade.
Old Feb 23, 2013 | 09:59 PM
GoFast908Z's Avatar
That can also make a smeary mess. Soapy water wipes away cleanly.
True, but the goal is ease of removal. Work smarter, not harder.
Old Feb 24, 2013 | 01:20 PM
k_cash1432's Avatar
True, but the goal is ease of removal. Work smarter, not harder.[/QUOTE
Ditto. I work for BNSF, all I hear about is working safe and doing everything by procedure, So warm water and baby soap, using a plastic scraper so i dont knick the rear defrosters. We got a foot of snow this week/end, so gonna shoot for next weekend when it warms up a lil bit.
Old Feb 24, 2013 | 04:51 PM
porksoda's Avatar
Proof from our brethren...https://ls1tech.com/forums/general-m...ve-winner.html
Old Feb 25, 2013 | 10:34 AM
J_O_E's Avatar
I'll add my .02 cents.
I've removed a tint from a few vehicles. My favorite way is soapy water and a blade, but depending on the vehicle I use the heat gun on occasion. Some have such terrible tint jobs in hard to reach places that the heat helps pull it back, but if you do that I recommend at least a paper paint mask because of the smell.
By Brett Foote | 2026-06-04 05:00:17
