Depo headlights super low
I also bought some Sylvania SilverStar ULTRA TWIN Halogen to go with em. I tried to do as much searching as possible and all I can come up with is readjusting the headlights. Is there anything I need to make them work correctly. I also see some sort of cover material in the lowbeam port that covers the headlight could that be whats taking away the visibility. sorry if this is a repost but I swear I cannot find what Im looking for. The lights look like they are aimed the same way as the stocks were.
A) if you're talking about the area circled in red in the attached picture, that is fairly normal for low beams to have that "cap", hell some low beam bulb (and fog lights) have painted tips on them that do what that does.
B)Before bothering with spacers or swapping stuff, there is some kind of adjustment screw or bolt head and in my experience (with my old honda) it can take quite a bit of turning to get it to start raising the beam pattern (sometimes they fall "off track") so make sure that isn't your problem.
C) make sure you installed them correctly (not familiar with camaro mounting points), on my honda I had 2 bolts on the bottom and 2 on the top make sure you have the bottom pulled forward when tightening and the top pushed back while tightening as this can significantly affect the angle of the lights.
Also, if you old headlight brackets are good on the old headlights, use them as they should be pretty close to where you want them, you may have to adjust them but it shouldn't be that much.
I had a set of projectors in mine and couldn't get them adjusted enough so finally, I came up and swapped out brackets and that fixed that. Now, the headlights are in my wifes car.
and I will mos def try that bracket swap out. Going to save up for some better lighting mods
