Wire mod for driver side
Old Apr 20, 2013 | 02:43 PM
Blownbayou's Avatar
Default Wire mod for driver side
Where did you guys ground the little wire on the driver side fender???? Looks like I can use the abs bracket, but would like to see what others have done.
Thanks
Old Apr 20, 2013 | 02:45 PM
babbage1109's Avatar
I drilled a hole under the fuse boxes and screwed it in there
Old Apr 20, 2013 | 03:15 PM
Blownbayou's Avatar
will move later... thanks
Old Jul 7, 2013 | 02:16 AM
NatesHawk's Avatar
There's a ground on the inner side of the subframe rail right behind the radiator.. I relocated both the ground off if the fender and the ground from the core support down to it, mounting all the grounds to the same point.. 4k miles ago no issues.. Was easier to do with the nose of the car in the air tho, had it up pulling the air pump off.. One of those while I'm here moments...
Old Jul 7, 2013 | 06:55 PM
skopers3's Avatar
i used the ABS bracket. No issues.
Old Jul 8, 2013 | 11:00 AM
Majestic9C1's Avatar
I used a pre-existing stud on the core support and used a castle nut I had laying around to secure it..
Old Jul 12, 2013 | 02:12 PM
99WS6MAN's Avatar
Old Jul 12, 2013 | 04:48 PM
1964_442's Avatar
i did use an existing hole , use a new bolt and nut .. pic added
Old Aug 7, 2013 | 08:57 PM
Wicked 94TA's Avatar
I saw someone hide the ground wire and put a nice stainless hex head bolt with a bowtie engraved on the head in the hole. Anybody seen them and know where to get them?
