Best tire shine/protectant
I need some help finding a good tire shine that will not only keep the tire walls looking great but also one that won't damage and deteriorate the tire over time. A friend was telling me to avoid products with silicates in them and suggested to find one that is water based. There are so many tire shines and dressings to choose from out there.....PLEASE HELP!!!
i'm a fan of meguiars endurashine and Venom Car Care Products 'Tire Venom' depending on what I want. I generally use the tire venom on my plasti dip and other rubber/plastic. It works great on tires, but I feel the endurashine tends to fling less on my tires with tons of little grooves and daily drivers that get washed weekly. I use the Venom on tires with minimal grooves.
I apply both by spraying on a rag and wiping on. I don't like shiny tires.
Don't know about the best but Zaino Z-16 Perfect Tire Gloss is pretty dang good.
http://www.zainostore.com/Merchant2/...oduct_Count=18
adams super vrt is excellent . Not the glossiest but has a decent life two-three washings or quite a while if you dont wash your nice day car . No sling and looks great .
Car Pro PERL. Amazing stuff. Depending on how you dilute it, it has many uses.
http://www.autogeekonline.net/forum/...rpro-perl.html
http://www.autogeek.net/perl-coat-protectant.html
I tried Armor All Extreme Tire Shine Gel and I've been pretty impressed. I figured it was gonna be some overpriced crap but it works great. It leaves a great subtle shine and lasts atleast 4 weeks that I know of. I don't know how protective it is but I know as far as appearance goes its great.
Our SuperVRT, as mentioned above, is one of our best sellers and is on sale right now in the Daily Special!
It's water-based, water-resistant, and contains SPF35 so it does a great job of protecting from the damaging effects of the sun. Dries to a nice, satin finish. If you're looking for a little more shine, apply a second thin coat and it will enhance the gloss a little.
As with any tire dressing, be sure to get any oxidation and old dressings off the surface before applying the fresh stuff. All Purpose Cleaner and a stiff bristled brush like our Tire Brush work perfectly here.
I looked up the Zaino Z-16 on their site and it looks like a very good product and says it's not oily and greasy. It also says it protects against UV and helps prevent cracking and browning, but I'm still not sure if it's water based.
Nick@Adams; I like the sound of the SuperVRT, and has a lot of good reviews. Can I get it in Canada anywhere or order it online? And how long does the tire shine usually last? Thanks
