dual state tint laws
here is the Georgia law
Revives the window tint statute which was recently found unconstitutional by the Georgia Supreme Court with some minor modifications.
"Makes it a misdemeanor to violate specified window-tint restrictions
· Applies to both residents & non-residents.
· No window tinting on front windshield.
· On windows to either side of driver or in back of vehicle, the light transmission restriction may not be less than 32%, plus or minus 3% or increase light reflectance more than 20%.
· Labels indicating that tinted windows meet state specifications are no longer required.
Exceptions:
1. Sun visors mounted on front windshields.
2. On front windshields - lower left and right corners in a 5" or 7" square (respectively).
3. On front windshields - Passenger Common Carrier Signs meeting statutory specifications.
4. Upper most 6" on front windshield can have a transparent item which is not red or amber.
5. Any Federal, state or county required stickers may be placed as required
6. Rear windshields & side windows behind the driver of a:
a. Multipurpose passenger vehicle
b. School bus
c. Public transportation bus
d. Non-profit bus
e. Limousines
f. Windows tinted before factory delivery
g. Tinting otherwise expressly permitted by federal law
7. Anywhere on law enforcement vehicle.
The DPS (DMVS until July 1) may issue dark tinting permits to persons with special medical needs requiring tinting. Any GA Installer installing tinting in violation of this section is guilty of a misdemeanor.
KRS 189.110 Unobstructed windshields -- Display of American flag -- Windshield wipers.
(1) A windshield in a fixed and upright position, that is equipped with safety glazing as required by federal safety-glazing material standards, is required on every motor vehicle which is operated on the public highways, roads, and streets, except on a motorcycle or implement of husbandry. (2) A person shall not operate a motor vehicle on a public highway, road, or street with any sign, sunscreening material, product, or covering attached to, or located in or upon the windshield, except the following: (a) A certificate or other paper required to be displayed by law; (b) Sunscreening material along a strip at the top of the windshield, if the material is transparent and does not encroach upon the driver's direct forward viewing area as defined in Federal Motor Vehicle Safety Standards No. 205 as the AS/1 portion of the windshield. (3) A person shall not operate a motor vehicle required to be registered in the Commonwealth, on a public highway, road, or street on which vehicle the side wings and side windows on either side forward of or adjacent to the operator's seat are composed of, covered by, or treated with any sunscreening material or other product or covering which has the effect of making the window nontransparent or which would alter the window's color, increase its reflectivity, or reduce its light transmittance, except as expressly permitted by this section. A sunscreening material may be applied to the windows if, when tested on one-eighth (1/8) inch clear glass, the material has a total solar reflectance of visible light of not more than twenty-five percent (25%) as measured on the nonfilm side and a light transmittance of at least thirty-five percent (35%) in the visible light range. (4) A person shall not operate a motor vehicle required to be registered in the Commonwealth, on a public highway, road, or street on which vehicle any windows behind the driver are composed of, covered by, or treated with any sunscreening material, or other product or material which has the effect of making the window nontransparent or which would alter the window's color, increase its reflectivity, or reduce its light transmittance, except as specified below: (a) Sunscreen material consisting of film which, when tested on one-eighth (1/8) inch clear glass, has a total solar reflectance of visible light of not more than thirty-five percent (35%) as measured on the nonfilm side and a light transmittance of at least eighteen percent (18%) in the visible light range; however, sunscreen material which, when tested on one-eighth (1/8) inch clear glass, has a total solar reflectance of visible light of not more than thirty-five percent (35%) as measured on the nonfilm side and a light transmittance of at least eight percent (8%) in the visible light range may be used on multipurpose passenger vehicles; (b) Perforated sunscreening material which, when tested in conjunction with existing glazing or film material, has a total reflectance of visible light of not more than thirty-five percent (35%) and a light transmittance of no less than thirty percent (30%). For those products or materials having different levels of reflectance, the highest reflectance from the product or material will be measured by dividing the area into sixteen (16) equal sections and averaging the overall reflectance. The measured reflectance of any of those sections may not exceed fifty percent (50%). (5) A person shall not operate a motor vehicle required to be registered in the Commonwealth, upon a public highway, road, or street, on which vehicle the rear window is composed of, covered by, or treated with any material which has the effect of making the window nontransparent, unless the vehicle is equipped with side mirrors on both sides. (6) Each installer or seller of sunscreening material shall provide a pressure-sensitive, self-destructive, nonremovable, vinyl-type film label to the purchaser stating that the material complies with the provisions of KRS 189.010(20) to (23) and subsections (1) to (5) of this section. Each installer shall affix the required label to the inside left door jamb of the motor vehicle. In addition, the label shall state the trade name of the material and the installer's or seller's business name. Labeling is not required for factory glazing which complies with Federal Motor Vehicle Safety Standard No. 205. (7) Every percentage measurement required by subsections (3) and (4) of this section is subject to a tolerance of plus or minus three percent (3%). (8) A person shall not install window tinting materials on a vehicle that fails to meet the minimum standards for light transmission pursuant to subsections (3) and (4) of this section. Tinted material that fails to meet the minimum standards for light transmission pursuant to subsections (3) and (4) of this section shall be removed immediately. (9) A person who applies sunscreening materials in violation of this section shall be guilty upon conviction of a Class B misdemeanor. (10) Nothing in this section shall prevent the display of a representation of the American flag on the rear window of any motor vehicle, including any vehicle owned by a local or state government, provided that the representation does not exceed a size of five (5) inches by eight (8) inches and is placed in a lower corner of the rear window. (11) The windshield on every motor vehicle shall be equipped with a device for cleaning rain, snow or other moisture from the windshield. The device shall be so constructed as to be controlled by the operator of the vehicle. (12) Nothing in this section shall be construed to prevent the use of any window which is composed of, covered by, or treated with any material or component in a manner approved by federal statute or regulation if the window was a component part of a vehicle at the time of the vehicle manufacture, or the replacement of any window by a covering which meets these requirements. Effective: July 15, 1994 History: Amended 1994 Ky. Acts ch. 42, sec. 11, effective July 15, 1994. History through 1968: Recodified 1942 Ky. Acts ch. 208, sec. 1, effective October 1, 1942, from Ky. Stat. sec. 2739g-69c.
