wheel wells detailing?
anybody have any good ideas how to get the wheel wells good and clean and keep them looking good? I do not own a pressure washer. been wondering if cleaning then rubber undercoating works well? paint? plasti-dip?
saw my car from a distance yesterday, and was like wow, clean except those nasty wheel wells.
I clean mines with the Adam's all-purpose cleaner, then spray them down with the Adam's invisible undercarriage spray, works great, they come out looking brand new each time.
The paint isn't a bad idea either. I might have to clean mine up and do that.
Did you guys paint just the plastic liner or the body color behind the suspension also?
I'll take some pics and get them uploaded. My car never drives on anything but pavement, so rocks and other debris is at a minimum. With that said, there are no chips or scratches at all so far. If there ever, were, it's an easy fix; just grab the spray paint and touch it up.
To reiterate what I did; I sprayed and wiped them down really well, let it dry, then used spray paint and sprayed the entire wheel-well area. You should only need to do this one time if you stay on top of making sure it's clean. Now, if you drive in the rain a lot, or drive on gravel or dirt roads, you may need to repeat it down the road.
