Sprinkler
Old Oct 9, 2013 | 07:49 PM
blackbirdls1's Avatar
Not sure what brand, it's not the rotating kind, it is the misting kind I Believe.
Old Oct 12, 2013 | 11:09 AM
Brutal Boba Fett's Avatar
If it is the misting kind you should be able to pull up the center top peice where the nozzle is located. Since it is spring loaded it shoul be easy to pull up. This is the nozzle and shaft section. The nozzle changes spray patterns, angels, and diameters. Twist of the nozzle and there should be a plastic filter in it. Throwing dirt in the filter can gum it up without causing any damage.
Old Oct 12, 2013 | 05:59 PM
sscamaroburn02's Avatar
Actually if u can get around the head, the top actually screws off and you can take out the guts or gum it all up so no water can come through.
Sent from my HTC One VX using IB AutoGroup
