Effective way to remove glass scratches?
Like a windshield or a rear window without replacing the window? Anything that doesn't just create a hazy mess?
Been finding this, but figured I'd ask.
http://www.eastwood.com/pro-glass-polishing-kit.html
Ideas?
Ideas?
here try looking before posting a topic exactly like one that was started just 2 weeks ago https://ls1tech.com/forums/appearanc...scratches.html
Douchebag On The Tree
Bayer, you have to just finely sand it and try to blend it well, then hope it looks good. I would try the kit.
There's just no need to be a dick in the first place, even more so when the information you link doesn't help at all.
Cerium oxide will take light scratches. If your fingernail gets hung in the scratch then you will have to basically grind the glass down and then polish. Cerium oxide is also good for hard steer spots and oxidation on glass.
Cleaning water spots is much different than getting actual scratches out of glass. That's like someone asking how to fix a scratch that goes through the clear and into the basecoat and you link a thread about polishing out swirls in the clear.
but for the record, taking a polishing compound and pad to glass is the same process it's just a matter of how much it takes to get it out if it is truely indeed a real scratch.
I wasn't being a dick, jackass (now I am), what I was getting at is what appears to be scratches (even feels like em) is often crud that gets on the window from the guides, so cleaning that crap off often gets everything.
Ideas?
Ideas?
Tip for removing hard water spots from glass: #0000 steel wool and white vinegar. The white vinegar will dissolve the deposits.
PLEASE BE SURE you purchase #0000 steel wool. There are many different kinds of abrasive steel wool and this is the finest. This is not the same steel wool you use for doing dishes or whatever else. I also use this and chrome polish to polish my chrome. The steel wool makes things so much easier.
