Brake residue is caked on my powder coated wheels...
I can't use wheel cleaners, regular water and soap won't do, and even degreaser won't dissolve the brake crud on the wheels. I tried scrubbing it off with sponge, micro fiber cloth and no dice. It started scratching the clear when I tried with the soap/water route with the sponge/microfiber cloth.
Any pointers?
Any pointers?
You beat me to it. I've used both and IMO Adam's is much better than Sonax. I did a pretty extensive comparison between the two. Adam's was able to get more of the deep brake dust off than the Sonax.
As mentioned Iron X will also work but it's not as thick as Adam's or Sonax and doesn't cling to the wheel as well.
You beat me to it. I've used both and IMO Adam's is much better than Sonax. I did a pretty extensive comparison between the two. Adam's was able to get more of the deep brake dust off than the Sonax. As mentioned Iron X will also work but it's not as thick as Adam's or Sonax and doesn't cling to the wheel as well.
Our Deep Wheel Cleaner will do the trick! http://www.adamspolishes.com/p-884-a...l-cleaner.aspx
I will vouch for the adams wheel cleaner too, it is really great stuff. Given your brake dust situation, coating the wheels with opticoat or cquartz will go a long way in making clean up much easier. A coating will crosslink bond with the clear and it will cause the brake dust to release much easier. I would seriously recommend looking into either. I prefer car pro cquartz since I switched from opticoat, but I dont have a bad thing to say about opticoat.
