Which color demon eyes should i pick?
I went to autozone and picked up some red high heat paint. The only one they had in red was 900 degrees so I got that. It is brake caliber paint. I'm hoping the red is bright enough to show up in the lens when you look at it. Will be posting the pics in the write up when I get my projectors on Friday. I also picked up some and in one satin black paint with primer so I can start on the headlight housings.
You running hi/low off the H1 or just low?
Careful with the lighter shades of red, when seen through the projector lens it looks lighter than it actually is. A darker shade of red to start with will give you a nice blood color. First time I did mine it looked watered down in the sun, went a shade darker and now its a nice full red. After you paint the shield lightly sand the top edge of it to knock off any loose over spray, don't want your cut-off line distorted.
Thanks everyone! Seems red is the winner. It is legal to have red painted shields as you can only see the red in the reflection of the lens from certain angles depending on how the light is hitting them. It is illegal to have red LEDs in the projector and having red demon eyes at night. And no, It is an appearance mod and does not affect the light output as long as you only paint the side of the shield that is facing the lens. Keep the opinions coming guys! I will be getting my projectors probably on Tuesday so there's still time for me to deside what color paint to buy!
I'm assuming the only projectors that will fit our cars are the mini H1s?
I kind of like some of the other shrouds on retrofit, but I'm not sure they'd fit our housings. It looks like 99% of the retro fit conversions are using the minis projectors followed with the mini shrouds
Red is gonna look great op, I'm excited to see how this turns out
Its not the only one that fits, its just by far the easist one to use as it needs virtually no fabrication skills at all. If you step up to something like a 3" fxr you need to beable to fabricate a way to mount it in the housing. Our housings are big enough to use a 3" projector though.
#32
Here is a reference that I'll be using.
http://9thcivic.com/forum/threads/fi...it.7466/page-2
#33
You paint the whole side of it, except for the sides of the solenoid and the spring. Just mask off those parts and I am even going to mask of the tippy top of the cutoff shield so I don't get any lumps of paint to effect the cutoff from being razor sharp. This is the whole thing painted a daskish gray. He picked gray, but you can paint it red like I will be doing.
There is another example without the solenoid painted. Basically the more surface area that's painted, the more of a reflection of red will be seen through the lens.
End result
End result
#34
I'd throw an LED back behind the shield, really seems to make the eye glow
here's a pretty in depth write-up I was checking out
http://www.hidplanet.com/forums/show...Halos-Red-LEDs
#35
My projectors will be here today but they are coming via UPS which doesn't normally deliver to my house until like 5:00 pm. Once they arrive, I have to paint the shields red and paint the shrouds black before I can seal them up into the headlights. So in all likelihood my write up won't be done until Saturday which is when I will probably finish getting the lights on the car and aimed perfectly.
I will keep you guys posted on this thread and let you know when the new write up thread will be up! I will try to make it as detailed as possible. Here is a sneak peak of what I have done so far...
Painted Satin Black
#36
Well I just checked the tracking number to see if the projectors were at least in the state I live in, and it says ''Adverse Weather Conditions'' and the projectors are in Illinois. The status before that was saying that they were departing out of Illinois 3 days ago. Needless to say, I am pretty pissed right now. Looks like I won't be getting my projectors tomorrow. Hopefully by Saturday but if not then I will have to wait for the NEXT week. I purchased these from TheRetrofitSource on the 12th and it is now the 21st. I am going to contact them and see what they can offer me because this just is BS...
#39
I am going to contact ups here in a minute. I wonder how long it is going to take for me to get my package. Illinois is still bacisally on the other side of the country from Washington. I checked the tracking number again and it still says the same thing. This really sucks because I have today and tomorrow off work and it would have allowed me to have the time needed to do this retrofit and write up. Looks like it is going to have to be another week. Sorry guys
