Camaro vs Firebird Steering Wheels?
You can get this wheel leather wrapped with radio controls out of 95-99 Monte Carlo as well. The ONLY difference is the color, the Monte Carlo version is a true black like the black on the 93-97 Camaro wheels and the 00-02 Camaro version is the really dark grey ebony color.
As far as I know, and from everything I've read on the web, there was NOT a change in wheel thickness between Camaro and Firebird. If you're comparing the older style wheels, (93-94 Firebird) or (93-98 Camaro) then I wouldn't know, nor care since those styles were definitely different.
Top Center-
Circumference: ~3" (7.62cm)
Diameter: ~.95" (2.42cm)
Right Side (above radio controls; center of thicker portion)-
Circumference: ~4" (10.16cm)
Diameter: ~1.27" (3.23cm)
My math might be a little off (I hated Geometry, so if someone needs to correct it, please do so).
