problem with HID. Ballast?
At first, the light would come on normally and then go out if I made a sharp turn. Then it started going out very soon after I turned the lights on and now immediately. The light flicks on and then immediately turns off.
Today I had a chance to look at it a little further. It's not the bulb as I switched them and the passenger bulb had the same issues when I switched but works perfectly on the original side. I pulled the bulb out of the housing and tried to narrow down the issue today, but was unsuccessful. Most times the bulb will go out immediately after I turned on the lights, sometimes it will flicker for 3-4 seconds before going out and once every 20 times or so it would turn on normally and then go out after I moved it at all.
Seems to me that it is a wiring issue inside the ballast and replacing it should solve the problem, but just wanted to solicit any other input before I order new a new ballast.
Thanks guys.
Thanks guys.
