Powder-coating - Surface Preparation ?
Old Mar 17, 2014 | 12:03 AM
ez2cdave's Avatar
Default Powder-coating - Surface Preparation ?
When powder-coating an item, like an aluminum intake manifold, is it better to leave the surface "as-cast" or to have a smooth, polished finish ?
I want a "rough" or "wrinkled" finish on the powder-coat and I want it to be durable.
Old Mar 17, 2014 | 09:02 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
We sand blast all the parts we manufacture to give the powder coat a nice, clean surface to attach itself to. If you aren't able to sand blast the item I would definitely clean it with some kind of degreasing solution at a minimum. Having a clean surface will allow the powder coat to stick to the item better and will offer a better overall finish.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Mar 17, 2014 | 02:14 PM
ez2cdave's Avatar
So, powder-coating adheres better to a rough, grainy surface, right ?
The reason I'm asking is that I wanted to know if a "satin" or "polished" manifold was the better starting point. I want to end up with a textured, "wrinkled finish in the powder-coat.
For an aluminum intake manifold, is there a particular type of powder-coat product I should look for ?
Thanks !
Old Mar 19, 2014 | 03:49 PM
ez2cdave's Avatar
A little help, please ?
Old Mar 19, 2014 | 04:00 PM
BMR Sales2's Avatar
Thanks !
You are correct, powder coating adheres to a clean, rough surface the best.
The finish you get will be determined by the powder coating you choose to use. They have different finishes of powder coating.
A good place to start to research this stuff is www.powderbuythepound.com, they sell powder coat there and they have a good forum with solid information.
__________________
Glenn ***
Sales Tech
813.986.9302
Old Mar 19, 2014 | 09:33 PM
DopeFedZ's Avatar
They sell powder that leaves a wrinkled finish.
Old Mar 21, 2014 | 01:36 PM
1 of 44's Avatar
Just like bodywork, the finish will be the same as whatever you are covering it with, when the powder melts it is VERY thin, so if you have a crack or a fuzz, you will see the crack or the fuzz once its coated. It does not fill in imperfections or bumps. If you want a bumpy surface, Blast it with red sand and coat it, if you want a smooth yet textured surface you can buy textured powder and blast it with walnut or glass or something to take minimal material away or just clean it really well like BMR sales said.
Old Mar 21, 2014 | 01:38 PM
1 of 44's Avatar
Also like BMR sales said, i buy all my powder from powderbuythepound.com they have good stuff.
Old Mar 22, 2014 | 09:52 PM
ez2cdave's Avatar
Thank you, guys ! ! !
