auto shifter
Old May 23, 2014 | 03:59 PM
1SCKLS1's Avatar
Default auto shifter
I want to change my ugly stock automatic shifter so I am going with the MBA automatic shifter adaptor from http://www.ws6project.com/user_stor/...ca067461b9de26 I can use a Hurst shifter what size sifter hole do I need to fit the adapter? and can I use a leather boot from a grand am? do I need anything else for this project if anyone has pictures can you please post them thank you!!
Old May 23, 2014 | 04:41 PM
crimson_bird's Avatar
M16 x 1.5 is the thread size I believe. The things you mentioned are all that you should need.
You can also shorten the shaft while you're at it, I think I did 3/4". I've been meaning to dig up my old pics to post them up. I'll see if I can find them.
Old May 23, 2014 | 10:10 PM
1SCKLS1's Avatar
thanks for your help I appreciate it man if you have any pictures that would be great thanks!! which Hurst shifter did you go with?
Old May 23, 2014 | 10:18 PM
1SCKLS1's Avatar
Amazon.com: Hurst 1530020 Universal Brushed Aluminum T-Handle: Automotive Amazon.com: Hurst 1530020 Universal Brushed Aluminum T-Handle: Automotive
would this be ok to use?
Old May 23, 2014 | 10:23 PM
Double-aught_Z/28's Avatar
I have one with a Hurst T-handle on it. I don't have any pics handy, but I'll try and get a couple for you tomorrow. The shifter boot from an early 2000s Impala fits nicely. I think I pulled mine out of an '03.
Old May 24, 2014 | 03:06 PM
Pics as promised:
Old May 24, 2014 | 03:56 PM
1SCKLS1's Avatar
Originally Posted by Double-aught_Z/28
Pics as promised:
that looks sick man thanks for the pictures Im just not sure what exact Hurst shifter to buy I don't want to buy the wrong one and it wont fit
Old May 24, 2014 | 04:58 PM
bad_408_vert's Avatar
Crimson
Can the hurst white ball or pistol grip shifter fit on this adapter ?
Old May 24, 2014 | 05:14 PM
99z28monster's Avatar
Originally Posted by bad_408_vert
Crimson
any shift **** that will fit on the M6 cars will fit the adapter.
Old May 24, 2014 | 05:51 PM
Ellsworth's Avatar
I need to get a shifter boot, you guys say out of a grand am will work?
MBA shifter and "ws6 engraved ball"
Old May 24, 2014 | 05:54 PM
^that. So if you're on any website that had a section with ***** specifically made for these cars they will work (ws6store, afterthoughtsauto, hawksthirdgenparts.com etc). You can also search in eBay with the thread size posted above to look for any other ones that may not be specific to these cars. I went with a shift ball from hawks third gen. Black with a good firebird on top.
Old May 24, 2014 | 05:59 PM
Mine is from a '00-'05 Impala. I believe Grand Ams of the same generation are the same.
Old May 24, 2014 | 08:25 PM
PontiacFan's Avatar
You will have to do some modifying to the underside of the console if you plan on adding the boot. Like removing some of the slide plates, etc.
Grand Prix, Grand Am, & many others will work, but you may have some trial & error during the fit.
I used a Grand Prix boot, & a Grand Prix **** that was recovered in leather, & the now button is now my line-lock.
(The flash from the camera really makes the center console colors look odd, ...)
Old May 24, 2014 | 10:44 PM
I had to remove the sliding plates, shove the boot up in there, and then reinstall the sliding bit; basically sandwiching the metal ring around the boot between the console the sliding thing. It's important that you keep the sliding louver things in there as they are what makes the gear indicator work.
Old May 25, 2014 | 12:34 AM
VIP1's Avatar
Copy & Paste Moderator
Here is how I installed my shift boot:
http://www.fadingarrow.com/ShiftBoot.htm
Its a universal leather shift boot.
I have a Trailblazer SS (TBSS) Shift **** on there now, with the same boot.
I don't have a pic of it installed, but here is babbage1109's car:
Redline Goods (a sponsor) also sells custom boots:
(I think babbage1109 - pic above - got his boot and center console cover from Redline Goods.)
Old May 25, 2014 | 01:40 PM
tnmotown's Avatar
Man these ***** looks better than the stocker one.
Maybe I'll have to do mine soon...
