custom hood project
Old Jun 15, 2014 | 11:02 AM
thunderlsx's Avatar
Default custom hood project
im molding a hood scoop onto my stock z28 hood. i started off with a bad warped aftermarket hood off a 96 ss some guy gave me in a trade. my stock z28 hood was already dented from where a tree limb fell on me going down the road awhile back. oem ss hoods are getting hard to find around here and everybody wants 100000 dollars for one, my other option is to buy an aftermarket that probably wont line up anyway. i had nothing to lose so i gave it a shot.
started off i cut the scoop out of the ss hood
then a test fit. it didnt fit the curve of the hood exactly so i cut some reliefs in it to bend it a little
i cut a whole for air flow to make it functional. then i fastened it down with countersink metal screws. when i cut the scoop out i left about 1.5 inches of the flat part to give me a wide flange for adhesive.
a veteran hot rodder told me to use marine epoxy as adhesive. the reason why is marine epoxy is designed to flex with hull movements. if done right it wont crack. i glued it down, fastened with screws. next i sanded and applied some evercoat body filler around the seam. theres still a lot of sanding to do...and i got some pinholes in my body filler but i think its fixable with sanding and priming. so far its looking good.
still some work to be done but its getting there.
Attached Thumbnails custom hood project-2014-03-15-13.35.50-small-.jpg   custom hood project-2014-05-26-14.18.33-small-.jpg   custom hood project-2014-05-27-17.41.30-small-.jpg   custom hood project-2014-06-14-16.31.55-small-.jpg   custom hood project-2014-06-14-16.32.19-small-.jpg
Old Jun 15, 2014 | 12:53 PM
jrpimp00's Avatar
looking good, any pics of the underside
Old Jun 15, 2014 | 06:05 PM
TechCam97's Avatar
Looks good, but as an FYI you should know that the scoop is shaped differently on the LT1 SS. It's more flat while the LS1 SS scoop is more rounded and "bulbous" in shape.
Old Jun 16, 2014 | 09:15 AM
tnmotown's Avatar
Looks pretty good so far. Keep us posted on the progress!
BTW, I like the look of LT1 SS hoods over LS1 style
Old Jun 23, 2014 | 10:59 PM
totalchaos's Avatar
looking good
Old Aug 13, 2014 | 07:13 PM
thunderlsx's Avatar
update...havent been able to do much till recently. sanded and put on one coat of primer today. its coming along.
Attached Thumbnails custom hood project-2014-08-13-17.52.18-small-.jpg   custom hood project-2014-08-13-17.52.43-small-.jpg   custom hood project-2014-08-13-17.52.54-small-.jpg   custom hood project-2014-08-13-17.53.19-small-.jpg
Old Aug 17, 2014 | 09:24 PM
whytryz28's Avatar
A+ work
Looks great.
Old Aug 18, 2014 | 02:29 AM
EFoxwell's Avatar
Looking good, bud.
Old Aug 31, 2014 | 09:58 PM
That_Z28_Camaro's Avatar
Looks sharp!
