How to restore plastic trim to factory condition-A quick guide
Heat gun and firm plastic brush are needed
one side before
other side after
new vs. old
Try to do as much as you can with the brush before you heat it, and make sure the surface is relatively clean. The brush will clean any dried plastic on the surface, and in some situations might be all you need if your plastic isn't in too bad. But if you have faded and worn plastic, you may need both. If that is the case, then the instructions are pretty straight forward: brush, heat, brush, repeat until it is to your liking. Remember not to let the heat sit on an area for too long, treat it the same way you would if you were spray painting, back and forth motion. It may take a while for the plastic to become black (took me about 15-20 mins for that front piece) but if you take your time, it lowers the chance of you melting the plastic, and if done correctly and not rushed, no harm will come to it. BUT if you rush and apply too much heat, you risk burning the plastic. Stay a couple of inches away when you apply heat (2-3 inches). The heat basically brings the pigment back to the surface of the plastic, which will give you a nice black sheen, better than any over the counter cover up.
Hope this helps you guys out, if you have any questions just ask below.
My friend took all his plastic trim off and paid a paint shop like $50.00 to spray paint it and then clear coat it. It shines black like crazy. I think Im gonna do that same. I think all he did was wet sand it a little bit before he gave it to them to paint.
I like to clean the plastic really well with 1z deep plastic cleaner and then coat it with CarPro Dlux. Restored and protected for up to one year, then just recoat it whenever it starts to fade.
