Question for HID gurus about brightness
Everything went smooth but I'm not happy with light output.
It's slightly better than stock and blue (whoopie!).
Projectors and all accessories are from the retrofit source.
The hid kit is xentec from eBay and bulb rating is 6000k.
I want that bright crisp light output like a Cadillac, my question is can I get away with buying just good quality bulbs or do I have to get full hid kit from retrofit source?
I feel the hid kit is weak link here because headlight lenses are clean.
Not sure if it is mainly the bulb or the ballast or a combination of both, but they suck. I bought a set of 35w HIDs from the retrofitsource and the difference is literally night and day.
You will see the improvement just by swapping to the Morimoto 3five ballasts, but for max lumens (light output) you need to be closer to the 3000k to 4300k temperature range, as you go higher the lumens get lower.
I personally would ditch all the components of your hid kit and upgrade your already good projectors with hid components from the retrofit source. I think youll be amazed at the difference.
