Anyone have problems with HID fogs?
I had LED foglight bulbs from Ebay last for 3 years in my G8 and they still worked when I traded it in on the Regal.
It also doesn't matter if it is Reflector or Projector. The Current LED Kits don't properly use the reflector to be useful/proper for main forward lighting. You may see more foreground lighting, but less distance lighting which is actually more important.
The exception is that some Halogen Projectors handle HID alight, but I have not yet seen any LED Kits that work correctly in any Projector or Reflector Headlight.
Like I said earlier, if you don't like the truth, ignore it and do what you want. However when you try to convince others to do the wrong thing there will always be those of us to point that out.
From the way you talk you have tried every LED on the market, which I find so hard to believe. So you can't say that they all don't work properly in halogen housings. Besides you don't understand the true purpose of foglights so what you say about LED bulbs is irrelevant.
However, funny as it may sound, I have seen some people use the front half of a projector as a "dummy" to turn into a turn signal. No it didn't help make them any more visible. It was done for aesthetics and not function.
As for LED drop-in kits, no I haven't tested every kit out there and neither have you so that failing argument works both ways. Either way, it is still simple physics (optics). You can test that theory out by moving the bulb around in the housing and see what that does to the beam pattern. Although I have not personally tested every kit out there, I have seen output shots of most of them. There really are only a few designs that get copied and new names put on them.
As I've asked now 3 times, if you want to prove me wrong, provide proof instead of the "it looks good to me" argument.
If you find a kit that uses a virtual filament (light guide) that is properly aimed and has sufficient output and doesn't burn out from poor design, please show it. That is one scenario that might possibly work sufficiently as a drop-in kit (especially in comparison to the current crop). A virtual filament / light guide is a clear "lens" added to guide the light into a shape similar to the original filament. Look inside some clear candelabra LED bulbs and you'll see what I mean.
Something like this:
(this is a prototype that upashi was working on)
http://www.hidplanet.com/forums/show...adlight/page12
His experimentation showed promise. The beam's hot spot wasn't as bright/intense as the original bulb (although it was much whiter), but the pattern was much closer than any current drop-in kit. I'd like to see further progress on this prototype to increase output and bring it to market.
This is the principle behind that light guide:
Although the shape would have to be a bit different to match the original filament.
Since you are done wasting everyone's time: Goodbye.
Before
After
Looks pretty good IMO. I taped it to the top area of the bumper, and soldered the connections together and use pvc shrink tubing to keep them protected. Looks a bit more modern
I got the 5050 led strip. That one has about half the amount of LEDs per meter. That way its not way too bright at night.
Thanks
Heres a pic I took from a bit farther away.
Sorry for the crappy cell phone pics. Once i get my BLS kit, ill pull out the nikon.
