Anyone have problems with HID fogs?
Old Jan 30, 2015 | 06:26 AM
ThoR294's Avatar
I tried HIDs in my fogs and they were just silly (LT trans am though). I put silverstars in them to give them a good look and put BLS in my headlights... I now know what to do from now on with any of my cars lol. Projector conversion HIDs in the headlights and silverstars in the fogs. Haven't tried LEDs yet but I heard they look good in fogs.
Old Jan 30, 2015 | 08:14 AM
98CayenneT/A's Avatar
Originally Posted by _JB_
I have HIDs in my DD fogs, and they appear to run cooler than the halogen bulbs (both 35w). After the HIDs are running for a few minutes, the lense is much cooler to the touch than halogens. Maybe 55w HIDs melt housing designed for 35w halogens (or whatever fbody stock fogs are)?
Ya, I have never seen 35w hids melt the housing. But good point, it's probably clowns putting 55w hids in there fogs for whatever reason that are melting
Old Jan 30, 2015 | 11:30 AM
Daniel Richards's Avatar
Originally Posted by Zlow28
Ive seen a trans am with Halos on the fog lights but cant find it anymore. Anyone here have those instead.
What you are looking for there is the Navigator NV-362W "driving" lights, they aren't really a fog light as the beam spread pattern is so different but they are the right size and easy enough to make fit and they are glass and metal instead of plastic, but you won't find HID's to fit them because of how shallow the 362's are and the type of bulb they use.
https://ls1tech.com/forums/appearanc...alo-s-t-s.html
https://ls1tech.com/forums/appearanc...8-formula.html
Old Jan 30, 2015 | 01:26 PM
Zlow28's Avatar
The ones i was looking for were on post #12 on the first link. Those look really clean.
Anyone know if LEDs in fog housings will create glare? I read they dont produce nearly as much light, but cant find any pics of that.
Old Jan 30, 2015 | 01:43 PM
here are some points of reference, the driver side fog is a 6000k HID in both pics, in the picture with the file name 4 the passenger is the stock halogen and picture with the file name 3 has a "6000k" LED cheapo Chinese piece of crap that looks like the ones in the third picture.
Attached Thumbnails Anyone have problems with HID fogs?-3.jpg   Anyone have problems with HID fogs?-4.jpg   Anyone have problems with HID fogs?-880-13.jpg
Old Jan 30, 2015 | 02:09 PM
WS6_101's Avatar
I melted a set of fog lights with my 35w HIDs, I have since switched to LT style fog lights but have just been running halogen bulbs. The issue I had was that the HID bulbs seemed to touch the lens on the housing when they were installed, which would cause the extra heat.
I would like to find a nice set of LED bulbs to throw in my fogs for the HID look, since there is zero light output from the fogs with either halogen or HIDs.
Old Jan 30, 2015 | 02:21 PM
Zlow28's Avatar
I cant believe i missed that. Those were the pics that convinced me not to buy the HIDs on the fogs. WAY more glare than i imagined.
The LED fogs dont look so bad. Im sure they wont be useful at all but hopefully i wont need the fogs with the BLS kit. Theyll be just for looks
Thanks
Old Jan 30, 2015 | 03:01 PM
Thanks
even with the headlights off and only the fogs and parking on those LED fogs barely reached the ground, they are strictly for attempting to match the color of HID headlights, I had already switched over to the NV362W lights before I did the BLS install but even the 362's in the base/formula front bumper being out on the ends instead of back "in the hole" on the T/A bumper only added a little "spread" of light off the sides, in a T/A bumper they would probably never be noticed. Personally I think the NV362W's where a closer match to the BLS kit with 5000k bulbs and still maintained a bright enough look that they didn't look like extra parking light like the LED's did.
Old Jan 30, 2015 | 08:28 PM
RedHotG8's Avatar
Thanks
The Cree LED bulbs do light up the road well, they are much brighter than the regular LED bulbs Daniel posted in the picture above. When I turn them on with the HID headlights on the roadway in front of the car gets brighter.
Old Jan 30, 2015 | 10:21 PM
Zlow28's Avatar
Do you get any glare with those? Or do you have any pics by any chance?
Old Jan 30, 2015 | 10:26 PM
RedHotG8's Avatar
Sorry I don't have any pics but I haven't had anyone flash their brights at me so I assume there's no glare.
Old Jan 31, 2015 | 12:50 AM
  #32
VIP1's Avatar
Copy & Paste Moderator
Those Cree LED still have the hotspot in the wrong place and some still have multiple LED which means multiple hot spots in the wrong places. You may find them brighter to your eyes but since the hot spot is in the wrong place the light isn't properly controlled and not going where it is supposed to. Which means incorrect beam and increased glare.
Old Jan 31, 2015 | 12:56 AM
  #33
RedHotG8's Avatar
Obviously you missed the part where I said the roadway gets lit up when I turn on the LED's with the HID headlights on, so they are casting bright useable light on the road not creating glare. When I say they are brighter that doesn't mean when I look at the lit up foglight housing.
Old Feb 1, 2015 | 06:18 PM
  #34
VIP1's Avatar
I didn't miss anything. You can believe what you want. You can't alter physics.
Park aimed at wall 20+ft showing before and after Halogen vs LED.
You will see a proper hotspot and controlled pattern with Halogen.
LED will may be brighter, but the hotspot will be missing and the beam will be altered.
Old Feb 1, 2015 | 06:31 PM
  #35
Zlow28's Avatar
Well i went ahead and ordered 880-WHP9 bulbs from super bright leds dot com. Theyre only like 11 bucks so ill try them and out and ill see if they dont have bad glare. I just want the rest of the car to match the BLS kit with as little glare as possible.
On a side note i also got 3156-xLX3-DI for the reverse lights. and a cheap ebay led strip for the license plate light. Ill post before and after pics when i get them.
Old Feb 1, 2015 | 06:38 PM
  #36
RedHotG8's Avatar
What does that have to do with the bulbs casting useable light on the roadway professor?
Old Feb 1, 2015 | 11:25 PM
  #37
SparkyJJO's Avatar
Because there is more to proper lighting than just usable light on the road, such as not also casting light into places it shouldn't go i.e. other driver's eyeballs.
Old Feb 1, 2015 | 11:29 PM
  #38
RedHotG8's Avatar
I haven't had anyone flash their brights at me so they must be focused correcly. Most foglights can be adjusted to aim the properly.
Old Feb 1, 2015 | 11:53 PM
  #39
Zlow28's Avatar
Just cus you havent been flashed doesnt mean you dont have glare in your headlights
Old Feb 2, 2015 | 08:58 AM
  #40
SparkyJJO's Avatar
I think your Buick has projector fogs so that will mitigate any issues due to the cutoff shield inside. Reflector housings don't have that.
