Trans and door panel technique / install
Old Apr 14, 2015 | 11:09 PM
Ghostintheshell's Avatar
Default Trans and door panel technique / install
Hey folks. I am just about to attempt my install of the door panel inserts.
I have read a few threads. Some people have used plastic weld or epoxy in an attempt to reattach the plastic that must ultimately be removed / damaged in the process.
I'm looking at getting a plastic weld hot air gun (60 bucks) and start at a really low temp and use some pliers to re-mold the shape of the plastic instead of actually removing it.
Has anyone done anything similar?
anything completely different?
I'd love to know what worked for folks and what didn't.
Thanks guys.
Old Apr 17, 2015 | 07:31 PM
mac62989's Avatar
I'm interested as well because Ill be doing the install hopefully the end of the month.
Old Apr 19, 2015 | 09:59 AM
01ssreda4's Avatar
If I remember correctly I used screws to replace the panel after I recovered it:
Old Apr 23, 2015 | 02:54 AM
balboa25's Avatar
Use a glue gun it worked well for me when I wrapped me door panels
Old Apr 23, 2015 | 07:56 AM
99WS6MAN's Avatar
x2 ... I plan to do mine soon
Old Jul 19, 2015 | 01:10 AM
Well any updates guys?
I had trouble tracking down a plastic welder that word ship to Canada so I'm still looking for an affordable option...
Old Jul 19, 2015 | 08:14 AM
01ssreda4's Avatar
Please reread the thread. You don't need a plastic welder.
Old Jul 19, 2015 | 05:16 PM
I've read it
It says that you can use screws / washers. Wasn't particularly detailed in the explanation - but I think I understand how they'd be used.
I've never seen a write up on the screw technique - but I'd imagine it being self tapping screw / washers.
I'd be worried about doing that on the trans am doors given the number of plastic pegs.
Old Jul 20, 2015 | 12:11 PM
VIP1's Avatar
Copy & Paste Moderator
On the flat tabs, use plastic epoxy or remelt them or put a small screw through them sideways. I used plastic epoxy.
The round pegs of the armrest are hollow tubes. I used screws with wide washers. If yours still have plastic "lid" to them, drill a small pilot hole.
Old Jul 23, 2015 | 01:33 PM
01ssreda4's Avatar
Panhead self tapping screws (which is all I buy) won't require a washer.
Old Jul 23, 2015 | 04:29 PM
VIP1's Avatar
I used pan head screws (not self-tapping/drill-tip though), but I'd still recommend wide washers to spread the load. The panel is cardboard.
