Hella 60mm question
So with that said, I don't see an issue running a higher wattage system in these modules.
If you want to save money on ballasts, check out the Fast Bright ballasts. I don't have any experience with them, but I've heard good things.
If you want to save money on bulbs, look in The Retrofit Source's closeout section for the previous generation Bulbs. Avoid "B" stock or "misaligned" bulbs. However, it looks like they only have the 3Five bulbs (35watt) right now and not the 5Five bulbs (55watt).
1. Stock Lighting
2. BLS V2 kit
3. LMC housings
4. LMC housings with HID kit
5. BLS V1 "budget" (basically a new set of hella 60mm combined with BLS mounting plates)
so with that said anyone buying LMC housings with the intent of shoving HIDs into them to save money STOP RIGHT NOW
lets run the numbers for a minute, LMC housings are 35 a piece plus shipping so you're looking like 80-90 to get them to your door, well thats what a set of hella projectors will cost you, then you just have an extra 60-70 for plates and mounting hardware and let me tell you this the Hella 60mm are LIGHT YEARS (LITERALLY NIGHT AND DAY DIFFERENCE) better then the LMC's with HIDs, with the LMC's there was plenty of light but it was like ambient light it was just there faintly lighting everything no real focus, not any more usable light then the halogens that come with them, the Hella's on the other hand (with the 50watt ballasts) are like the surface of the freaking sun, nice wide beam spread and lots of USABLE light, while having a cut-off to prevent blinding on-coming traffic, if I have one complaint about them it is the size of the step in the cut-off.In short anyone thinking about buying the LMC to put HID in just buy the Budget BLS kit.
1. Stock Lighting
2. BLS V2 kit
3. LMC housings
Does anyone have a road shot of the step in the Hella 60 mm? I want to see how bad the step really is because I know it's fairly large aimed against a wall.
5000k bulbs with 50 watt ballasts.
