Custom Door panel take 1
so here is what I am starting with. I'm partway thru the first panel swap right now and it's going fairly smoothly, I need to get some screws and washer to put the handle section back on tomorrow, I'll also be retinting the windows tomorrow.
also pictured is the 5 other tabs that have to be cut off to get the speaker pod, door pocket panel off.
edit: on second thought cut off the white tubes level with the side of the armrest they stick out of, this will allow you to pull the armrest tight up against the cardboard insert.
