Need help finding Projectors
Old Dec 26, 2015 | 02:18 PM
Txw1ck3d's Avatar
Default Need help finding Projectors
Bought these and well the h1 bulb is not great, sucks really. So will a Hid bulb help this or not? Or should I got with a new set of headlights with a better bulb in it so I can get the hid with the better bulb size.
Old Dec 26, 2015 | 05:28 PM
Majestic9C1's Avatar
go with The Retrofit Source or BlackBird Lighting Solutions
Old Dec 26, 2015 | 11:34 PM
VIP1's Avatar
Copy & Paste Moderator
For some people, putting in an HID Kit helps a bit, but the real problem is the poor design and quality of those aftermarket projectors. They can't produce a proper beam pattern and they don't last.
Your best bet is to either buy a set retrofitted with better projectors or do it yourself. Look in the Lighting FAQ for more info. (https://ls1tech.com/forums/appearanc...hting-faq.html)
Old Dec 27, 2015 | 10:08 PM
THEF4NG's Avatar
Something like this.
Same headlight housing as yours. Just modified to fit mini h1 projectors.
Old Dec 29, 2015 | 11:53 AM
BLSolutions's Avatar
If you are interested in a complete setup, feel free to drop us a PM or email. We offer plug and play solutions which will outperform any of the existing aftermarket lights available.
Old Dec 29, 2015 | 12:45 PM
$750 L98's Avatar
Blackbird Lighting is the only one I buy retrofit units from. Don't bother with anything else.
Old Dec 30, 2015 | 06:10 PM
imma_stocker's Avatar
What would you recommend for a 98-02 Camaro that already has the DDM plug-n-play HID upgrade? Will these 35W fit your headlights just like stock?
Took the car out at night and noticed all street signs were a big glare so there is certainly some light scattering.
NOTE: I do not know the terminology of these things. The wires go to a ballast and more wires go to something that makes light. AFAIK HIDs are alien magic.
Old Jan 1, 2016 | 10:55 PM
ThoR294's Avatar
BLS sells just his lights, minus the HIDs
