Trans Am LED Fog Light Install (Morimoto Knockoffs)
#202
Also didn't get some of the orange fogs from outside the vehicle like I did the white. When I drive the car on the way to work one morning, I'll try to get some from the driver's seat.
#204
Just finished mine, and I gotta say, they are great but my beam pattern doesn't seem to be as wide as everyone's here. First off, my fogs sit much deeper inside the bumper than I see most of the people in here do. I believe that's why my beam pattern isn't as wide, because the bumper is cutting it off.
Also where are you all getting the spacers from? I couldn't find any at Home Depot.
What do you all think?
![Name: 20161102_222627_zpsn4qgztk0.jpg
Size: 225.3 KB](https://ls1tech.com/forums/attachments/appearance-detailing/594941d1501256073-trans-am-led-fog-light-install-morimoto-knockoffs-20161102_222627_zpsn4qgztk0.jpg)
![Name: 20161102_214450_zpssrtyud6o.jpg
Size: 290.8 KB](https://ls1tech.com/forums/attachments/appearance-detailing/594942d1501256073-trans-am-led-fog-light-install-morimoto-knockoffs-20161102_214450_zpssrtyud6o.jpg)
![Name: 20161102_214418_zpsrlqpfqwl.jpg
Size: 340.5 KB](https://ls1tech.com/forums/attachments/appearance-detailing/594943d1501256073-trans-am-led-fog-light-install-morimoto-knockoffs-20161102_214418_zpsrlqpfqwl.jpg)
![Name: 20161102_175605_zpshacploty.jpg
Size: 259.4 KB](https://ls1tech.com/forums/attachments/appearance-detailing/594944d1501256073-trans-am-led-fog-light-install-morimoto-knockoffs-20161102_175605_zpshacploty.jpg)
![Name: 20161102_214440_zpsojjkojuw.jpg
Size: 357.7 KB](https://ls1tech.com/forums/attachments/appearance-detailing/594945d1501256073-trans-am-led-fog-light-install-morimoto-knockoffs-20161102_214440_zpsojjkojuw.jpg)
![Name: 20161102_215635_zpspjzoieon.jpg
Size: 325.8 KB](https://ls1tech.com/forums/attachments/appearance-detailing/594946d1501256073-trans-am-led-fog-light-install-morimoto-knockoffs-20161102_215635_zpspjzoieon.jpg)
![Name: 20161102_215433_zpsk9hnru6x.jpg
Size: 295.4 KB](https://ls1tech.com/forums/attachments/appearance-detailing/594947d1501256073-trans-am-led-fog-light-install-morimoto-knockoffs-20161102_215433_zpsk9hnru6x.jpg)
![Name: 20161102_215645_zpswgmsdfxo.jpg
Size: 349.0 KB](https://ls1tech.com/forums/attachments/appearance-detailing/594948d1501256073-trans-am-led-fog-light-install-morimoto-knockoffs-20161102_215645_zpswgmsdfxo.jpg)
Chris,
Chris,
#207
I ordered these lights awhile back and about to put them in soon myself, prob next weekend hopefully. I will have to add some pictures when I do.
Infinite, what headlight/mod is that you did? If I missed in the thread my bad. I just recently did all projectors, going to modify more for actual LEDs to go in them soon.
I almost DD my car, so light is important to me lol almost have the entire car switched over to new/led lights
#208
Copy & Paste Moderator
Which projectors and which LEDs? Most drop-in LEDs don't use the optics well enough and have poor beam pattern. Even the ones that come close aren't quite right, but some are passable. So it depends on which ones you are considering.
#209
I'm curious too.
#215
Sorry been busy and haven't got to finish this project yet, oddly mine have the dot number at the top with the wire kinda off to the side and the bottom. But I am happy with them over the stock lights, especially for the cheap price.
The projectors I used were the hellas, and with those plates you can find on ebay, took some slight modifying but the lights are so much better then stock. I haven't put LED ones to put in them to try yet, I need to cut some of the stock headlight bracket off the back cause the fan/controls/wires def wont allow it go down as-is. Probably be something I finish in the spring.
#217
I just got a new Hella and re-installed my projectors last weekend. Just couldn't deal with the reflector housings anymore.
Remove shrouds, remove original light, take off adjusters and undo corner spring and bucket will drop out. Install the projectors into the new plates and they bolt in place of the actually old bucket, so just reinstall adjusters and spring and you're good. Out of everything, the aligning of the headlights afterwards is the worse part IMO.
