Removing burnout rubber?
Old May 24, 2016 | 02:37 PM
STAR's Avatar
Default Removing burnout rubber?
Hey guys, what's the best way to remove old rubber (3 years old) from the rear quarter panels? Someone mentioned using varsol, but I don't want to damage the paint.
What has successfully worked for you?
Old May 24, 2016 | 03:27 PM
Dirty Dog's Avatar
Elbow grease...
If you spray PAM on the fender, it'll keep rubber bits from sticking.
Old May 24, 2016 | 03:42 PM
LT4vert's Avatar
Carpro Tar X is some amazing stufff and wont harm the paint.
Old May 24, 2016 | 04:36 PM
CanadianEh!'s Avatar
Believe it or not - spray WD40 on it and wipe with paper towel. Keep spraying and using fresh towels and you can get it spotless with a little elbow grease!
Old May 24, 2016 | 07:38 PM
STAR's Avatar
Pam is great if planning ahead.
I will try wd-40 and see what happens.
Thanks
Old May 24, 2016 | 07:46 PM
The Guz's Avatar
Stones Tarminator
Old May 24, 2016 | 09:29 PM
Dirty Dog's Avatar
Thanks
Just spray it on every morning. Because every day is a good day for a burn out...
Old May 25, 2016 | 07:48 AM
STAR's Avatar
Haha...your right
Old May 25, 2016 | 08:14 AM
Rise of the Phoenix's Avatar
I had good luck with using my finger to get it off. Get it good and wet with soapy water, let it penetrate it a bit, and then see what wipes off and what doesn't. Whatever doesn't, use your finger(s) and rub back and forth until it comes off. I would spray WD-40 on the rear quarters to keep it from sticking on there in the future.
Old May 25, 2016 | 08:25 PM
insidethreat07's Avatar
WD-40. Then i always put a coat of wax on it afterwards
Old May 26, 2016 | 12:31 PM
Firebirdmuscle's Avatar
I always use wd-40. I spray my rear fenders with it and wipe it smooth before each race day. But as stated above. If it's already on there, just keep wiping with new paper towels and it will come right off.
Old May 26, 2016 | 12:38 PM
thunderstruck507's Avatar
I always used WD40 when my car was painted. Also takes off road tar and tree sap without hurting the paint.
