"Professional" paint correction
Is there a best practice to do this? Does it differ depending on the manufacturer of the ceramic coating?
Perl to me seems like a thicker Reload.
I will give DLUX a try.
No it does not really differ from manufacturer
I first washed the car. Then I basically washed it again using my synthetic clay bar. Honestly, the finish felt perfectly smooth once washed but I clayed it anyway. That seems to have removed all the old wax which was fine with me. I then went over the car with the machine using Griot's 3-in-1. I let that dry a bit while I polished the stainless exhaust tips and put away some of my cleaning supplies. I then went over it again with Meguair's Carnuba Plus. I let that dry while I did the windows and plastic and leather. I then buffed it by hand with a microfiber and went over it again with a clean one. Here's what I got.
But with paint correction type compounds/polishes you can work the product harder with a DA polisher so a higher setting like a 4/5 setting. If it was vibrating bad might have had too much pressure pushing down and not centered enough or maybe most likely not enough pressure on the DA. Also I'd check to make sure the pad was centered, some guys like to take a marker and mark the top of the polisher disk that the pad attaches to with a black line so they can help monitor if they are applying too much pressure by seeing if that mark is spinning or not.
Don't quote me on everything as I could be off lol, we definitely have guys one here with great experience in this area. I think that can help is to go to Autogeek.net and watch his videos on how to do a lot of these tasks. Usually the videos are pretty good on explaining what and why which helps in confidence.
In the video they are measuring in mills.
25.4 microns = 1 mill = .001"
The picture below shows approximately how much polish you should use each time.
Also, to do any real correction you need to be around setting 4-5.
CarPro Reset
CarPro Dlux
DI Applicator pad
Nanoskin Autoscrub
Carpro Quartz applicator
CarPro Leather Coating
Tarminator
Optimum No Rinse
HydroSilex Foam Cannon to replace my Gilmour Foamaster which I dislike
Microfiber wash mitt
Still trying to decide on drying towels and microfibers to wipe car down. I also want to buy some products to correct the subpar detail this car got previously. If you see anything I should get over what I've picked Id appreciate the recommendations.
Probably gonna buy a new machine too as I had a Griots previously, while it worked decently it wasn't as good as the Rupes 21 I used. Are there machines that are about as good as Rupes without the price tag haha?
CarPro Reset
CarPro Dlux
DI Applicator pad
Nanoskin Autoscrub
Tarminator
Optimum No Rinse
Microfibers
The Rag Company
CarPro Reset
CarPro Dlux
DI Applicator pad
Nanoskin Autoscrub
Tarminator
Optimum No Rinse
I will go into more detail but leather protector is recommended for leathers 3 years or older. It will nourish the leather and then 12 hours later apply leather shield which add abrasion resistance and dye color transfer. Great stuff. It may not last as long as cquartz leather but it feels a whole lot better.
Are you planning to clay and correct? I didn't read all the way back but I see you mentioned ceramic coating was on the paint. Are you planning to re-coat?
My Esky ESV isn't coated but I plan on doing a full correction on it and coating it as well. The conditioner is for it as the Hawk has cloth seats
