Dual Action Buffer question.........
Old Sep 12, 2019 | 05:35 AM
stilealive's Avatar
Default Dual Action Buffer question.........
If I use products like "H Speed" or "Victory Nano Polish and Seal", if thee paint looks perfect once I go over the whole car with it, is it really left with a protective coating for 4-5 months. Or do I still need to then put a coat of something like Meguiars Ultimate Wax on the clear coat by hand as usual?
I'm just curious if those two products actually leave sufficient protection behind after one pass......
Old Sep 12, 2019 | 07:49 AM
HioSSilver's Avatar
I use lucas slick mist after i wash a car. For as easy to use as the stuff is it really seems to leave a nice protective coating on it. I use it on the glass also. I don't use the wipers when it rains now.
Old Sep 12, 2019 | 09:11 AM
stilealive's Avatar
Im just curious if the DA buffer type products is all you need to do.....ONE application. Is the clear coat protected as if a coat of Meguiars wax was put on the car?
Old Sep 12, 2019 | 09:20 AM
98CayenneT/A's Avatar
I don't use any of the products you mentioned but Carpro Essence is a very good ceramic based polish/ primer that gives very good gloss and will last longer than any meguiars wax.
Old Sep 12, 2019 | 11:21 AM
HioSSilver's Avatar
I don't use a da buffer. Often wondered if they worked well. But typically i use transtar tri-cut for a compound then change from wool to foam pads accordingly. I'll finish off stuff i want really nice with 3m stage 2 then stage 3.
Nothing i have seen on the market is a one application type thing......and I've done this stuff for 30+ years. Now the label might say it and if your car leads a pampered life you might get by with it for a while. But constant use takes constant maintenance.
Maguire's stuff is **** imo.....other than their run of the mill cleaner wax from walmart. That stuff is decent.
Old Sep 12, 2019 | 05:33 PM
stilealive's Avatar
The DAs do amazing on the clear coat......
That’s why I want to try it out. My clear coat looks really damn nice but it can also use some minor paint correction too. I’ve seen cars before and after.....it makes them look like brand new paint jobs.
Ive used the Meguiars for a couple years now.....water beads and it stays in the car for a good 5 months....you can feel it’s still there with your fingernails....
But i want to use the DA and then also do a coat of something else after. I’m not buying it that it’s an all in one single pass deal....no way.
Old Sep 12, 2019 | 05:38 PM
Carpro essence will remove fine defects and does not need to be followed up with anything.
Old Sep 12, 2019 | 05:59 PM
stilealive's Avatar
You have a link to the exact Carpro product?
ill check it out. But man....how can any product do both, slight compounding and leave a coat of real sealant?
Is Carpro applied with a DA buffer?
You know anything about Drive Auto Appearance.....Victory Nano Polish and Sealant.
Old Sep 17, 2019 | 03:00 AM
The Guz's Avatar
If you are referring to 3D/HD Speed then it is what is referred to as an AIO (All In One). Another name for it is a cleaner wax. It will clean, polish and protect. Speed is an abrasive AIO. The downside to the product is it's lack of longevity. It is common to to top it with another product such as a sealant. I am not familiar with victory so you will have to research that brand on your own.
Durability is going to vary based on ones surrounding environment and how well the paint is cared for.
The only thing is that Essence by itself is not hydrophobic. It is hydrophilic. It is more of a finishing polish than it is an AIO.
Unless you are doing a ceramic coating I would not bother with Essence. It is an abrasive finishing polish with minor filling capabilities that is used as a primer polish prior to applying a cquartz coating. Essence by itself is not hydrophobic. It is actually hydrophilic. CarPro at a minimum recommends topping it with Reload.
Old Sep 24, 2019 | 05:44 AM
This I did not know, thanks much for that information.
I have never used Essence by itself but use it on every job. Imo Carpro absolutley nailed it with Essence.
Old Sep 24, 2019 | 12:32 PM
The Guz's Avatar
I agree Essence is a great finishing polish in prep for one of their coatings. Essence Plus is the hydrophobic version and there are some that use Essence topped with Essence Plus, using Essence Plus as a sealant.Essence Plus is ok in my experience.
Old Sep 25, 2019 | 01:15 PM
stilealive's Avatar
Ok.....so I need to buy a correction product. Should I go with Carpro Essence after I clay the car? Then Carpro Essence Plus as the sealant afterwards?
Is this a combo that customers pay good money for......?
Old Sep 25, 2019 | 01:38 PM
Essence plus is to correct a vehicle that is coated already.
You could do Essence followed by any wax, sealant or coating of your choice.
Old Sep 26, 2019 | 02:09 AM
The Guz's Avatar
If you already bought the products in your original post then you have no need for either of these.
Old Sep 26, 2019 | 09:59 AM
stilealive's Avatar
Not yet, I'll buy thee Victory stuff next week. Along with their Victory Sealant.
My car is in the shop till next week anyway......
Old Nov 7, 2019 | 02:54 PM
LilJayV10's Avatar
If you finish with Essence you don't "have to" put anything on it but it's recommend to top it with Reload. Reload has better contact and sliding angles. It mimics as if the car was coated.
Old Nov 7, 2019 | 03:20 PM
stilealive's Avatar
I just did my car yesterday with Griots 3-in-1.
Amazing results. I started a thread with pictures.
Question now......how long will it protect. Hopefully 3-4 months until it needs another coat.
Old Nov 7, 2019 | 04:22 PM
Depends on how you wash it, did you use a wax or a sealant? Does it sit in direct sunlight day after day?
If it's a carnauba wax..... maybe a week or two.
If it's a sealant..... anywhere from 1 month to 4 months+.
Old Nov 7, 2019 | 05:14 PM
stilealive's Avatar
My car is parked inside a parking garage, so only in the sun/rain when I drive it. The water kept beading up pretty good after 5-6 months with just my Meguiars Ultimate Wax.
This stuff I just used says "long-Lasting" Carnuba protection........LOL....not that I believe all the marketing BS from any company. Thats why in my other thread I kept asking everyone if I need to use a sealant AFTER I use one of these Paint Correction type products. I guess if Carnuba is crap for longevity I'll put a coat off my Meguiars on this weekend, over what I just did.
Old Nov 8, 2019 | 11:24 AM
stilealive's Avatar
98CayenneT/A,
I know you mentioned you don't like Meguiars, but it absolutely lasts 5-6 months on my car. Beading water, feeling nice and smooth by touch, etc....
If I put the Meguiars on my Orbital pad, along with the Griots 3-in-1 and applied it to the car.....would that leave the protection of the Meguiars product on the car after removing everything, as well and doing its job as a paid (clear) correction product?
If that will work, what's your best choice for a final sealant product to apply to the car? Maybe after this bottle of Meguiars runs out I'll go with a better product.
