Plastic Dash Panel Replacement
Old Jan 7, 2022 | 06:42 PM
dw456post's Avatar
Default Plastic Dash Panel Replacement
Who makes the best replacement panel for the front part of the dash ?? Most look pretty flimsy. 2000 Camaro coupe
Old Jan 7, 2022 | 06:43 PM
dw456post's Avatar
Old Jan 7, 2022 | 08:26 PM
01CamaroSSTx's Avatar
Well the OEM replacements are pricey if you can find one but they've come out with these cheap covers that glue onto the original upper dash panel.
Old Jan 8, 2022 | 05:34 AM
dw456post's Avatar
The OEM's are about 700 bucks---too much. I need one of those glue on pieces, but a good one. Hope somebody knows the good from the bad ones. The original piece broke into about a hundred pieces. Looked like broken glass.
Old Jan 8, 2022 | 08:14 AM
https://dashskin.com/97-02-camaro-fi...Lw_wcB#143=149
Made in the U.S.A. and it's the one you'll find from other vendors.
Old Jan 9, 2022 | 10:53 AM
dw456post's Avatar
Thanks!! I have seen a bunch of them, but didn't know which one I should order.
Old Jan 9, 2022 | 05:06 PM
wannafbody's Avatar
Camaro central used to sell an ABS version. Not sure if they carry it any longer.
Old Jan 15, 2022 | 05:39 PM
dw456post's Avatar
Thanks, I checked and they don't
Old Jan 22, 2022 | 04:09 AM
DopeFedZ's Avatar
the dashskin one fits nice if you lay it on top of the original even if it is broke. if you try and use it by itself which I have done before it will eventually start to warp due to heat and it being thin.
Old Jan 22, 2022 | 10:51 AM
wannafbody's Avatar
Coverlay makes a dash face skin cover(not the top pad) for those who have cracked dashes.
Old Mar 26, 2022 | 02:12 PM
2JAWZ's Avatar
I've actually seen someone take the cover and use it in place of the original cover. They glued the end pieces on to it where your a pillar molding sits on it to lock it in place at the edges and it honestly didn't look bad at all. If I ever replace mine its what I plan to do as well
Old Mar 29, 2022 | 09:22 PM
DopeFedZ's Avatar
I did that. It looks ok for a bit but the cover is pretty thin so even just running the defrost in the car will make the vent area start to warp.
Old Mar 31, 2022 | 02:38 PM
LilJayV10's Avatar
This is exactly what happened to me. I should have just dropped the coin and bought an OEM replacement.
Old Mar 31, 2022 | 03:38 PM
Nathan C's Avatar
Classic industries has OEM replacements.
Old Mar 31, 2022 | 09:04 PM
DopeFedZ's Avatar
the fit pretty good if you attach them to the stock broken one.
