Best glass cleaner for windshield
Old Mar 9, 2022 | 03:37 AM
RONIN LSX's Avatar
Default Best glass cleaner for windshield
I have these weird patches on my windshield, which are very noticeable when it rains. Like the arch of travel from the wiper and just weird blotchy spots here and there. You can't even see it, when the windshield is dry, but it's VERY noticeable when raining; almost to the point of impairment.
I read that acetone or mineral spirits can be used, but I'm worried about messing up my paint.
Old Mar 9, 2022 | 04:22 AM
98CayenneT/A's Avatar
If it's a base coat/ clear coat acetone will not mess up the paint.
I see what you are describing often. Contaminants just built up over time and glass cleaner will more often then not be unable to remove it.
The best way would be to do a machine polish with a da polisher, foam cutting pad and a cutting compound. The windshield clarity will be night and day using a automotive abrasive compound to remove years of build up on the windshield.
If you would like more info/ product recommendations let me know. Or if you're from Minnesota hit me up.
Old Mar 9, 2022 | 07:34 AM
ramairetransam's Avatar
clay bar the windshield , use a flat blade razor to clean the windshield the best you can then claybar and use a rain x when your done .
Old Mar 9, 2022 | 08:16 AM
Roarin_8's Avatar
You can also try a glass stripper: https://www.invisibleglass.com/produ...t/91411CSTON01
Old Mar 9, 2022 | 09:18 AM
NC01TA's Avatar
For decades on end I have used regular rubbing alcohol of 70% or higher. Fully wet a small cloth and rub the entire glass surface hard. No need to get the cloth dripping wet but enough to fully wet the cloth. Then use water and a microfiber cloth to make the glass 'like new' again. You may have to do it twice. I have used Rain-X afterwards on occasion when I go on long trips. That helps prevent build-up of crud again. Change or fully clean the wipers often too so you don't spread the problem all over again. It really can build up on the blades.
Old Mar 9, 2022 | 02:13 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Zaino makes a glass polish (Z-12) that has worked wonders on such problems, in my experience. It has a similar consistency as toothpaste. I just use it by hand with a terry pad, but for really bad areas I'm sure you'd get quicker results with a power appliance.
For a maintenance (and interior) glass cleaner, I only use Dirtex (by Savogran). This contains ammonia, so I wouldn't use it on tinting paper.
Old Mar 11, 2022 | 03:55 PM
RONIN LSX's Avatar
Here's a weird one - How about oven cleaner?
A friend of mine said it works on the glass in her oven, so I guess that it kind'of makes sense. No?
Old Mar 12, 2022 | 06:54 PM
LLLosingit's Avatar
I wouldn't chance it myself, A good glass polish should do it. As far as oven cleaner and working on oven glass.... I bet she doesn't look through it like you do a windshield
Old Apr 13, 2022 | 05:40 AM
tom33's Avatar
I dont even glass polish. ..just a normal water, wet duster, and dry one. DA Shipping
