gauge replace
When I had my 93 I did it, the wierd thing is the tach would only work with an MSD digital 6 ignition box hooked up. But it does fit it does work and you probably won't have the tach problem with the 96. You HAVE TO MAKE sure it is a 97 though the 98+ will fit its the same gauges but they are calibrated different......
Hope that helps
Hope that helps
The odometer works but the mileage is saved in the gauges itself. If you wanted the mileage to be correct you could check with a dealer I don't know mine was 10k off and I just told the person I sold it to the correct milage.
So I would do the change if you plan on selling the car in the next few years not really worth it.
