help with clear corner lights!!
Old Nov 1, 2004 | 08:17 PM
BES Stroked Nova's Avatar
Default help with clear corner lights!!
anyone have a trick with putting these one. I am new to here, and just got these today, and i think they would look killer on my silver z-28!! please help!!!
Old Nov 1, 2004 | 08:29 PM
blackls1maro's Avatar
i just did this a few weeks ago. all you have to do is:
-disconnect high and low beams
-remove the 10mm bolt to remove the headlights
-pop off the 5 or 7? plastic rivets that hold on the fascia
-disconnect the wires from the corner lights
-remove the 3 7mm bolts that hold on the corners.
install is the opposite. hope this helps! if it doesn't, do a search on this board, there are better tutorials out there.
Rick'SSOM's Avatar
https://ls1tech.com/forums/showthrea...+CLEAR+CORNERS
Old Nov 1, 2004 | 08:31 PM
1999Z28's Avatar
hey man, it sucks, some people say pull the headlights and it only takes minutes. I on the other hand like most went from the bottom and it takes a lot of effort. From the bottom, get all the plastic plates (or whatever to call them) out of the way and u can get a ratchet up there...from what i recall, there is 2 bolts. Once they're out, u can pull really hard and take a chance at scraping the front bumper, if it digs in the corner wrong it will. or take ur time and try and pull out the headlight. if u just bearly file down the corner on the new ones, bc it isn't seen once they're in, they will slide in much easier.
good luck.
Old Nov 1, 2004 | 08:42 PM
MyKeE's Avatar
follow the instructions from the link above... members here have used it and say its pretty easy... i did mine from the bottom...what a pain in the ***
Here's a tip... (not about install though) some clear corners have a problem with water getting in them so it would be a good idea to put some clear RVT sealant around them... you could also drill some small holes on the bottom of the lenses so water can drain out incase you do get this problem.
Not all clear corners have this problem though... but i would rather do it to be safe. and it would be better to do it before u put them on than to have to take 'em off later if the problem occurs
Old Nov 1, 2004 | 08:59 PM
Rick'SSOM's Avatar
IMO Dont go from the bottom,
remove the headlight,I have had mine in & out 1\2 a dozon times,or more trying to fix the leaks
no more clears for me
3 bolts hold them in,2 from the side, one from the bottom,11\32 I beleive
Old Nov 1, 2004 | 09:38 PM
Stangkilr's Avatar
I can have them swapped out in 5 min. Thats me though. Go from the top!!
Old Nov 1, 2004 | 10:40 PM
superchannelkev's Avatar
HA 5mins! you're slow I can do em in 2!!! j/k
Old Nov 1, 2004 | 10:50 PM
glitch77's Avatar
Go from the top by removing the headlights. Its still a pain in the ***, but nothing like going throught he bottom.
Old Nov 1, 2004 | 10:59 PM
Arachnotron's Avatar
I just installed mine. Take the headlights out. It's not hard.
http://homepage.mac.com/arachnotron/...es/corners.jpg
Old Nov 1, 2004 | 11:11 PM
DARK AGE 53's Avatar
I think if you follow the link Ricks99Z has posted you should be fine, as other's have said just take your time.
Al
Old Nov 1, 2004 | 11:30 PM
well, i got it finished really easy about an hour ago, thanks for the link, it really helps, now time to get some sleep for school tomorrow
Old Nov 2, 2004 | 01:47 PM
Steve1969LS1's Avatar
Yea.. its easy if you pull out the headlights first
Old Nov 2, 2004 | 05:47 PM
skewba98z28's Avatar
I did mine from the bottom yeah it sucked. You have to break the stock ones to get them out without pulling the front bumper off. new ones went in easy after sanding the corners down.
