Cobra shift knob questions Answered...
Old 12-07-2004, 03:00 AM
DVST8OR's Avatar
Default Cobra shift **** questions Answered...
I have been getting a lot of pm's on this mod and I wanted to clear a few things up.
This seems to be the general consesus of the questions "Will the shift **** fit our handles?"
The answer is no. The mustang handle threads are much smaller / skinnier than our shift handles.
Now you have two options to get the cobra shift **** to fit.
Option 1 : simply re-thread whichever handle you have, stock, pro 5.0, ripper, lou short stick, whatever, to except the smaller threads of the cobra shift ****. Or you can re-thread the cobra **** to accept the larger f-body threads, its up to you.
Option 2 : the option that I went with, is a little more complicated. First you need to own (or purchase) a Pro 5.0 shifter. Now all you need to do is find a mustang shift handle for the pro 5.0. Just the handle not the entire shifter, which looks just like this :
I found mine on ebay. All it is is the shift handle for the Pro 5.0 for the mustang. It bolts directly up to the Pro 5.0 wether it be for the Camaro/firebird or the mustang. Then just screw on the cobra shift **** since you now have a mustang handle that will of course accept the mustang thread size.
DO NOT GET THESE HANDLES, they will hit the bottom of the console when going into any of the bottom gears, i.e. 2,4,6
Hope this helps, let me know if you guys need any other info on this.
Brian
Old 12-08-2004, 02:46 AM
DVST8OR's Avatar
Don't know if we can make this a stickey? It is probably not popular enough of a mod. But there is nothing wrong with asking
Old 01-14-2005, 11:29 AM
99FormulaM6's Avatar
well, i have a question...how do i rethread my handle to accept the ****?
Old 01-14-2005, 11:57 AM
1998TA__1991RS's Avatar
my guess would be a tap and die kit with the right die for the threads
Old 01-14-2005, 12:17 PM
Brett95z's Avatar
you could always just drill and tap the **** for your bigger handle.
Old 01-14-2005, 12:25 PM
are either of those hard? never done it before...
Old 01-14-2005, 11:07 PM
Brett95z's Avatar
You need a drill and a tap. Just drill the hole in the **** out to the required size, and thread a tap into it. Total time ~10 minutes.
Old 01-14-2005, 11:48 PM
LSUxBlake's Avatar
I'm just having issues finding a tap in 16 x 1.5 . You need a 14.5mm drill bit btw.
Old 01-15-2005, 08:03 AM
what do you mean, thread a tap into it. sorry for my ignorance.
Old 01-15-2005, 08:03 PM
Brett95z's Avatar
Alot of metric threads have a sae counterpart that is nearly identical, and will work just find. Especially if you are threading into plastic, it wont bind it will thread like butter.
Old 01-15-2005, 09:25 PM
Black Z/28's Avatar
Here's the sae version that I used:
Old 01-15-2005, 11:41 PM
hey black z/28...you should thread my cobra **** for me if i ever get one im in norfolk
Old 01-16-2005, 01:15 AM
SCamaroS's Avatar
Can anyone post more pics of this **** cuz I think it looks sweet.
Old 01-16-2005, 08:06 AM
Black Z/28's Avatar
When you get it, ship it up here, I'll thread it for you.
-Jay
Old 01-16-2005, 12:22 PM
a98ws6's Avatar
I just took my short stick, grinded all the threads off and then cut new threads for it. Didnt drill anything.
Old 01-16-2005, 01:16 PM
LSUxBlake's Avatar
I was hesitant about buying the 5/8 because I wasn't 100% sure if it would fit. I just decided to order a 29 dollar Pro 5.0 stick yesterday, I figure I would have spent close to that buying a tap and die set anyway.
Old 01-16-2005, 01:35 PM
Black Z/28's Avatar
I just took my Cobra ****, drilled out the existing threads and then tapped new threads for it. Didnt grind anything.
Just messing with you. I thought about doing it that way. But re-tapping the **** allows you to put the old **** back on, or any other **** made for our shifters.
Old 01-16-2005, 03:19 PM
how did you cut new threads?
Old 01-16-2005, 03:36 PM
Brett95z's Avatar
99ForumlaM6, the only proper way to cut new threads is on a lathe. I made myself a hole new stick with the threads for the cobra **** already on it.
Old 01-16-2005, 03:40 PM
thats what i figured, but i was hoping there was another way... wanna make another
Quick Reply: Cobra shift knob questions Answered...
