Painting Berger Panel help!
Old Jan 11, 2005 | 11:15 PM
Poik's Avatar
Default Painting Berger Panel help!
I am going to purchase a used tail panel and I plan to paint it flat black like the Berger panels. What is necessary for surface prep? What kind of paint should I use (Spray Can)? Any tips, advice? Thanks.
Old Jan 11, 2005 | 11:27 PM
AW/whiteZ-28's Avatar
400 grit paper to sand off clear coat then 800 to sand it smooth paint it with a satin, low gloss, or flat black. light coats at first to cover the part then go a little heavier to smooth it all out then after it has dried wet sand if necessary. here's a close up shot of mine you should try to for a look like tht when it's dry.
BTW: I used duplicolor low gloss engine paint I had laying around
Old Jan 11, 2005 | 11:34 PM
texada's Avatar
I took my rear panel off and cleaned it. I then painted a gray primer and when it dried I painted it gloss black. It looks just like it came on the car from the factory.
Old Jan 12, 2005 | 12:57 AM
Poik's Avatar
Cool, thanks guys. Anyone know of any tutorial or something for wet-sanding?
Old Jan 12, 2005 | 02:35 AM
Basically just keep the area you are sanding wet and make sure the paper is wet and clean.
Easiest thing to do it get a bucket with water and a little soap, (helps keep grease/oil off the paint) a rag, and sanding block with paper. (I used 800 I think... maybe 1100?)
The rag is used to squeeze water on the part when needed.
Old Jan 12, 2005 | 07:30 AM
pailheadz28's Avatar
How lightly do you sand it after the final coat of paint? I'm finishing up my panel and need to do the final wetsand. I've got both 1500grit and 2000grit wet/dry sandpaper.
Old Jan 12, 2005 | 10:24 AM
LS1thunder's Avatar
If the panel has rough spots then lightly sand them with the wet 1500 or 2000. If you do not have any small bumps then just bolt it up.
If anybody else is thinking of doing this, I used spray cans of Bumper Black paint from Walmart. It is was a satin black and has some flex agent added. I also did an SS grill with the same paint. It turned out nice as well.
Old Jan 12, 2005 | 07:38 PM
Texas Heat's Avatar
I just finished mine today and used the same "bumper black". It turned out really good too.
Old Jan 12, 2005 | 08:56 PM
Joker's Avatar
So is there any type of clearcoat applied to the final paint coat to protect it after you wetsand it?
Can you polish and wax it?
Thanks!
Old Jan 12, 2005 | 09:14 PM
Danny2tek's Avatar
Thanks!
Thats what I want to know too!
Old Jan 12, 2005 | 11:32 PM
You can put satin clear coat on it if you want but you don't need wax a flat color. wax at say a car wash is fine but I wouldn't use paste wax it might soak it up.
