removing emblem
Old 03-05-2005, 05:22 PM
2000blackta's Avatar
Question removing emblem
How can i get the ws6 emblem off the back of my car without tearing up the paint?
Old 03-05-2005, 05:35 PM
1madss's Avatar
A blow dryer and dental floss. Then use WD40 to remove the residue. The WD40 will take off any wax as well.
Old 03-05-2005, 05:42 PM
Nova5's Avatar
heat gun / hair dryer (takes longer as its not as hot as a heat gun)
Fishing line.
Heat the emblem up then use the fishing line behind it to cut between the tape and paint. the line won't damage your paint and the heat helped loosen it. then use some Goo Gone or such to remove the remenents of the tape goo.
Old 03-05-2005, 05:44 PM
awesome guys, thank you very much!
Old 03-06-2005, 08:21 PM
ruck98's Avatar
i removed the emblems from my car but there was excess glue left over i have tried waxing but it still will not come off.
Old 03-06-2005, 10:27 PM
Restricted User
Blakbird24's Avatar
I just spray Goo Gone behind the emblem (spray in from the top pretty heavily and let it soak into the tape. Then the fishing line/dental floss process, or even one of those plastic bondo blades works well. Just be patient and take your time.
